Got wired !
Old May 25, 2008 | 10:34 AM
tip49's Avatar
tip49
Got wired !
Made some progress yesterday ; I've been working on getting the wiring harness through the firewall. Soldered all leads passing throught the firewall; now routing and eliminating circuits from donor harness as I go. Of course I "misplaced" the Chilton manual I had for the donor. I got the ignition switch back in , using a series, push, pull start circuit. Hoped to use the throttle **** on the pull switch but haven't come up with how to fit to the after market one yet. Put the battery back in, hope to work on it today.
Spring projects include 30 sq ft of patio stones in the rain.
Later
Tom
Old May 25, 2008 | 12:35 PM
Old F1's Avatar
Old F1
Originally Posted by tip49
Spring projects include 30 sq ft of patio stones in the rain.Later Tom
Bad plan, once you start doing that kind of work your truck time will continue to decline. You have to have discipline and a rule that it is truck work only! Of course you will be doing the cooking and your own clothes washing by yourself but sacrifices have to be made!
Old May 26, 2008 | 09:45 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Tom,
My wife wanting patio pavers also. I cussed and dug out the area all the while gently steering the converstation to concrete whenever I could. Finally one day my neighbor was over and we tag teamed her, the next weekend I was able to pour some concrete.
Heck, I even got it done in time that morning to go to a car show in the afternoon....lol
When I did my wire harness (I used the EZ Wiring 21 circuit harness) and I need to make a butt connection or a end terminal. I used the standard crimp on terminals but I didn't crimp them. Instead, with a small punch I pushed the terminals out of the plastic sleeve and then I soldered them onto the wires and then covered it with heat shrink tubing. I found it made a neater looking connections.
The crimping process always bends the connector slightly and I don't relly like the look of the colored plastic sleeves everywhere.
Bobby
Old May 26, 2008 | 08:05 PM
tip49's Avatar
tip49
300 sq ft
Bobby , I gave the soldering connectors to wire some thought, will have another go at it. I'm roughing in everything, tracing wires, get it running then final wiring clean-up. I hear you on the concrete, actually I have 300 sq ft to lay, did 100 sq today in the rain ! Wet wife, am eating my own cooking tonight.
I seem to have way too many wires going to start and run terminals because of the EFI, I 'm considering some sort of splitter to get rid of clutter.
Later
Tom
Old May 27, 2008 | 05:39 PM
tip49's Avatar
tip49
Finished getting wires soldered
Ooops - Got to remember to size photo before posting, pics are in my gallery under cab mods.
Later
Tom
Old May 28, 2008 | 07:55 AM
bobbytnm's Avatar
bobbytnm
Wow! I just love that Sheridan Blue, I've been leaning in that direction (of course it will be several years before I can even begin to think seriously about it)
Those late model gauges look excellent in the cluster! What will you use for a speedo head?
Keep plugging away a it, that is going to be one sweet truck!
Bobby
Old May 29, 2008 | 01:23 PM
tip49's Avatar
tip49
Bobby;
I've been looking at speedos, want close to stock look but have electric speed sensor so need to go with donor that matches up. I'm going to haunt wreckers this summer for candidates, Ford preferred. I hope to have wiring complete in 10 days , on my next days off.
Later
Tom
Old May 29, 2008 | 02:06 PM
bobbytnm's Avatar
bobbytnm
Tom,
That might be a bit of a problem. You will probalby end up having to carve the actual speedometer gauge out of a complete cluster as most late model (electronic) gauges are unitized. I'm guessing that Ford went to all electric gauges somewhere in the late 80's early 90's so there's bound to be something that will work.
Worst case scenario is having to work up your own faceplate for a late model guage
Bobby
