Modular V10 (6.8l)
What year
Old May 24, 2008 | 07:21 PM
cc322's Avatar
cc322
What year
was the v10 first produced?
Old May 24, 2008 | 07:35 PM
ol'yeller's Avatar
ol'yeller
I know part of the answer. the first year it was installed in the F250 was '99. It was available at least a year or more earlier in the motorhome chassis. Someone who knows the exact answer will be along shortly.
Old May 24, 2008 | 09:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It was in the E series in 1997.
Old May 25, 2008 | 11:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yup '97 in the e-series.
2000 was the first model-year for the "PI" heads with higher HP and torque.
2005 was the first model-year for the 3-valve. E-series do NOT get the 3-valve, nor does the Excursion for 2005.
Old May 27, 2008 | 07:28 AM
MarkMoore's Avatar
MarkMoore
According to Wikipedia...
6.8 L V10
The 6.8 L (6763 cc, 413 CID) V10 is another variation of the Modular family created for use in large trucks. Bore size is 90.2 mm (3.552 in) and stroke is 105.8 mm (4.165 in), identical to the 5.4 L V8. Both 2-valve and 3-valve versions are currently produced. The 6.8 L uses a balance shaft to quell vibrations inherent to a 90° bank angle V10 engine configuration. The 2-valve version, built at Ford's Windsor, Ontario LVL engine line, was first introduced in 1997. For 2005, Ford introduced a 3-valve version of the 6.8 L V10. The 3-valve engine is built alongside the 2-valve engine at Ford's Windsor, Ontario engine plant.
Vehicles equipped with the 6.8 L V10 Modular engine include the following:
2-valve
1997-present Ford E-Series, 2-valve SOHC, 305 hp (227 kW) and 420 lb·ft (569 N·m) ratings for 2001 and later model years
1999-2004 Ford F-Series Super Duty, 2-valve SOHC, 310 hp (231 kW) and 425 lb·ft (576 N·m) ratings for 2001 and later model years
2000-2005 Ford Excursion, 2-valve SOHC, 310 hp (231 kW) and 425 lb·ft (576 N·m) ratings for 2001 and later model years
3-valve
2005-present Ford F-Series Super Duty, 3-valve SOHC, 362 hp (270 kW) and 457 lb·ft (620 N·m).
Old May 27, 2008 | 04:03 PM
krewat's Avatar
krewat
So much for Wikipedia.
The high(middle)-output V10 came out for the 2000 model year. For the SD anyway.
