no start help
Old May 24, 2008 | 05:07 PM
macmillanracing's Avatar
macmillanracing
no start help
I'm trying to troubleshoot a no start condition on my 92' F150 (e4od,302). I remote started it on one of the last cold winter mournings, she started for about 30 seconds and sputtered then died. I was using the 'efi no start guide' on sbftech. I have fuel pressure, pump primes. She just cranks, doesn't even sputter when I carb cleaner into the intake. Injectors are pulsing. The truck already has a new fuel filter & sparkplugs w/ 8.8m wires. I tried swapping a known good coil. Following the guide, it said that 'at this point, it's either the TFI module or stator sensor.' So, I got my hands on an ACCEL billet distributor & TFI module with no luck. Still won't start. I've checked & rechecked timing so I'm sure I'm good there. I'm wondering if there is something internal on the motor that went wrong. I'm going to pickup a compression tester tomorrow. Just wondering if anyone has any suggestions on what I might've missed. Thank you.
Old May 24, 2008 | 06:02 PM
danr1's Avatar
danr1
You said fuel pump runs and trying a different coil but didn't say if you know for sure you had key "on" power to the coil and the ignition module?
Also you said the injectors pulsing but didn't say how you know, have key "on" power to them too?
Hot wire it, if it runs then you know you have a connection problem. The connection at the coil on that setup can and does.....well......suck.
How bout the remote starter? Unplug it and see if it starts.
Old May 24, 2008 | 07:46 PM
macmillanracing
Sorry if my first post was a little incoherent, this is getting frustrating. I checked injector pulses by connecting testlight to injector plug & cranking engine. I loosened the dizzy hold down & pulled the plug wire from the coil tower, with ignition on I could get the spark to jump from coil tower to plug wire holding it at a 1/4" gap or so by turning the dizzy back & forth. For the coil harness, I have 12V on the + side and 12V pulses on the negative side. I disconnected the remote starters lead to the coil but haven't disconnected the whole thing, I'll have to give that a try tomorrow. thanks for the reply
Old May 25, 2008 | 04:00 PM
Popa Tim's Avatar
Popa Tim
Pull a plug and with your thumb over the hole have someone turn the engine over. You should feel the compression blow your thumb off the hole.
Using the spark plug you pulled, connect it to the wire and touch the electrode end to the block and have someone turn the engine over. You should see a spark (so don't be holding the plug ) also you should be able to smell some gas from that cylinder thats un-plugged
If you have compression, spark & fuel and its still not firing you need to check for timing and a (really) plugged exhaust
CWPottenger
Jul 20, 2012 07:58 AM
Chevy 6.2D
Dec 29, 2009 03:58 PM
vintagerider50
Aftermarket Products
Mar 18, 2005 09:36 AM
big4x4bronco
Nov 11, 2003 07:14 PM
wecoyote5
Mar 24, 2003 08:40 PM
