Light Problem
Old May 24, 2008 | 06:40 AM
trike1946's Avatar
trike1946
Question Light Problem
My F350 has an electric gremlin. When I turn on the light switch, key on or off, the lights come on. But when I turn the switch off, the lights do not go off. I have to pull the fuse and then they go off. When I put it back they stay off. I tried pulling the relays under the hood but it did not affect the lights. Is there a relay that could be stuck somewhere? I tried another switch but it did not do anything. Thanks for any help.
Old May 24, 2008 | 06:52 AM
megawatt00's Avatar
megawatt00
There is a relay that controls them. I believe that it is under the dash (drivers side) I'm pretty sure that it is a timer relay. You said that you changed a switch, have you sprayed the latches with wd-40? Is your door ajar light on?
Old May 24, 2008 | 06:08 PM
trike1946's Avatar
trike1946
The door ajar light is not on. It is all the lights that stay on, headlights and running lights. There is a 20 amp mini fuse that I pull, under the hood, to shut everything off. Whatever the problem, I did not know about it before because the fuse was burned out. It was only since I replaced the fuse that this started to happen. I have only had the truck a short time and never had a trailer hooked to it before. It started when I was hooking up a trailer and checked the lights. I had signals and stop lights but no running lights. I looked at the mini fuse and saw it was bad. When I replaced it, still no running lights on the trailer, and the lights do not turn off. This is with the trailer plugged in or not and key on or off.
Old May 24, 2008 | 07:23 PM
F350-6's Avatar
F350-6
Maybe Jim's on to something with the timer relay. Have you left the lights on, closed the door and then just watched to see if they stay on permanently or go out after a while?
Old May 24, 2008 | 08:15 PM
megawatt00's Avatar
megawatt00
If I have this right it is your exterior lights that are acting up and not your interior (dome) lights. If it is the interior lights I would look at the headlight switch. I had a 98 F250 7.3 the headlights went out found a blown fuse, the headlight switch practially melted and blew the fuse.
Old May 25, 2008 | 05:27 AM
trike1946's Avatar
trike1946
Yes, the exterior lights are the problem. If I turn everything on and then turn the switch off, all the lights stay on. And I still have no running lights to the trailer if I hook it up. And I tried a new switch but it did not help.
Old May 25, 2008 | 05:35 AM
ron's power stroke's Avatar
ron's power stroke
have you checked the trailer plug at the stock harness behind the back bumper ??? check and clean all plugs under there....are your lights on a timer?? try waiting a couple minutes and see if they go out....
Old May 25, 2008 | 05:49 AM
trike1946's Avatar
trike1946
I don't think they have a timer. They always went out when I turned the switch off before. I guess the trailer running lights are a seperate issue. I will check the plugs for that part. Is there a seperate relay for the truck lights somewhere? I tried all the ones under the hood,
Old May 25, 2008 | 06:11 AM
ron's power stroke
http://www.7point3.com/AETips/Docs/Fuses.pdf
scrole down for diesel trucks..
Old May 25, 2008 | 09:05 AM
megawatt00's Avatar
megawatt00
Here is the wiring diagram for the 01 F350 with out daytime running lights. The only thing that I can see (I'm going to print it out and study it more) would be the switch on the steering cloumn.
Sorry I could'nt up load the pic.
Here is where i got it:
EBSCO Publishing Service Selection Page
Old May 27, 2008 | 05:40 PM
trike1946's Avatar
trike1946
It took a while but I found the relay. It is behind the dash just left of the radio and down a bit. There are 3 relays together. A big blue one and 2 smaller black ones. It was the black one towards the front of the truck. If you pull the radio you can get to them. I would think Ford could have put them in a better place.
Thanks for the help. I appreciate it.
abe
Jul 30, 2014 07:56 PM
p51man
Electrical Systems/Wiring
Sep 26, 2013 06:49 PM
johniebomb
Jan 25, 2012 01:09 PM
Rusty_S
General Automotive Discussion
Dec 8, 2010 01:42 PM
ssimpson6
Jul 4, 2010 10:42 AM
