Didn't start!
Old May 24, 2008 | 10:39 PM
1eyedjack's Avatar
1eyedjack
Didn't start!
Hello fordsters
This afternoon I fueled up my 2005 f250. After fueling up, my truck wouldn't fire up. It would just crank over and over. After sitting 30 sum minutes for the tow guy I tried it again and it fired right up. I drove it a few places shutting it off and on and it was fine, then it happend again. Has this happend to anyone else? anyone have a clue what is causing this?
Old May 24, 2008 | 10:46 PM
brickie's Avatar
brickie
Hpop fitting most likely. Use the search feature and grab a cold one its "a normal fix' on an 05.
Old May 24, 2008 | 11:11 PM
1eyedjack's Avatar
1eyedjack
will do.. thanks
Old May 25, 2008 | 11:11 PM
russ_d_t's Avatar
russ_d_t
Ive been fighting this problem with my 04 for almost 2 years now. First it was an oil pressure sensor located just in front of the turbo. I just got the PU back again the other day and the dealer determined it was the wiring harness. Apparently they have a problem with the harness rubbing against a coolant hose(???).
Old May 27, 2008 | 12:49 PM
fordboy2's Avatar
fordboy2
1eyedjack, mine just did this about a month ago, it was the hpop fitting. Really common on 05-06's I would bet that it is the same on yours.
