ford ranger flywheel keeps breaking??
Old 11-25-2004, 08:16 AM
imxscarredxtoo's Avatar
imxscarredxtoo
imxscarredxtoo is offline
i have a 1988 ford ranger 4x4 2.9 .the problem is the flywheel keeps breaking every other week.does anyone have a solution to this problem?
Old 11-25-2004, 11:10 AM
loudfords's Avatar
loudfords
loudfords is offline
Is it manual or automatic? Does it have the engine-tranny alignment dowels in place? Is the harmonic balancer still in good condition? These are things that can lead to broken flywheels.
Old 11-25-2004, 05:10 PM
imxscarredxtoo
its a automatic trans. the trans dowel pins are lined up ,the trans wouldnt fit if they wouldnt be,or would the starter.
Old 11-26-2004, 08:55 AM
kotzy's Avatar
kotzy
kotzy is offline
Transmission alignment with the engine is most critical, however if it is the original
transmission/engine combination I can't see why that would change, unless the bolts came loose and the pilot holes got opened up. Any work done to the transmission?
Old 11-26-2004, 11:58 AM
hotrodfeguy's Avatar
hotrodfeguy
hotrodfeguy is offline
It may be possible you dont have the converter in all the way.
Old 11-26-2004, 01:47 PM
loudfords's Avatar
loudfords
Also make sure bolts in crankshaft are torqued evenly, make sure torque convertor bolts torqued properly too, as loose bolts break things too.
If you have the dowels in place, I would suggest checking that you have the proper flywheel and harmonic balancer. Does the engine vibrate or shake at all?
Old 11-27-2004, 05:58 PM
canzus's Avatar
canzus
canzus is offline
A question for imxscarredxtoo, *where* is the flex plate breaking?
If it's around the crank flange, you may need a spreader plate...
SteveL
Jim Baldwin
01-16-2016 05:50 PM
johncart
40
09-29-2008 12:05 AM
tylstruck
02-18-2008 02:22 PM
poorfolks
08-22-2004 02:10 AM
jsorg76f250
01-27-2002 03:59 PM
Quick Reply: ford ranger flywheel keeps breaking??
