Sponsored by: Real Truck
excessive play in the wheel
Old May 23, 2008 | 07:02 PM
larrygranny1's Avatar
larrygranny1
my 08 F250 has been in the shop for two days. the play in the steering wheel is from 10-2 I have to constantly play the wheel to keep going stright. Ford says nothing is wrong. ANyone able to give me any ideas?
Old May 23, 2008 | 07:26 PM
ReAX's Avatar
ReAX
Sounds like the gear box needs a little tightening. On older boxes, there is a screw on top that you can tighten a little at a time. That may sure up the wheel a bit. Is it isolated to the box or could it be something in the alignment or rag joints?
Old May 23, 2008 | 09:03 PM
vincewood30's Avatar
vincewood30
It could also be the bushing in the steering wheel that is cracked. I had the same problem with my '05 E-150 van and they had to replace the whole steering wheel.
Old May 23, 2008 | 09:28 PM
mcjones44us's Avatar
mcjones44us
be careful adjusting the gear box. It's really easy to make it worse. Don't ask me how I know.
Old May 27, 2008 | 07:57 PM
jeffdoerr's Avatar
jeffdoerr
its a new truck, should not be your problem to fix or adjust. get a 2nd opinion, go to another dealer. I had to on my truck. local dealer was a waste of time. other dealer was awsome and got the job done.
Old May 27, 2008 | 09:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Good point on finding another dealer.
10-2 is pretty bad - that's unreasonable on a brand-new truck.
Report back what you find out!
