Towing Question--need help asap
You want to pull 9000 pound trailer with a half ton gas pick-up? Wow that will suck!
With two horses, hay and tack it comes in around 7000lbs loaded. The 99 expedition seemed to be not enough truck for the trailer.
i havent read through every reply, but these are the first two that i found. i agree that for that 25k lb trailer you are pulling that a diesel would be a better fit. the durability of a diesel vs a gas is a no brainer. but no one "needs" a diesel for a 5-10k lb trailer. people have their preferences, which is fine, but to say a gasser wont pull it just isnt true and is giving people false information.
the best answer to any "will my truck tow my camper" question is simple.....hook it up and find out. take off for a 10 minute drive and you wont need our opinion lol. he already has the truck and trailer, so thats an easy answer to figure out. my answer would be different if he didnt have the truck and was looking to buy one. id recommend a diesel for many reasons, not just power. but no need in trading in a perfectly capable truck he already has.
i took you saying it wasnt enough truck for it as in it didnt have the power to pull it. cant argue on the brakes though. i wouldnt pull 5k lbs in a 1/2 ton without a good set of trailer brakes. or without taking my time and keeping a good distance behind the car in front of me.
ive been going through and reading a lot of the older posts(new member here), and in virtually every thread where a guy says "i have this truck, can i pull this trailer" it generally only takes a few replies before some dumb*** chimes in with this reply "gassers suck, buy a diesel." and it just kind of got me aggravated lol. not everyone wants a diesel and that wasnt even part of their question to start with. theres a ton of reasons to go diesel if you dont have a truck and are looking to buy one. better mpg, durability, resale value, etc. but as far as pure pulling power, a newer 7.5 will eat a stock obs psd alive. they have the same peak torque, hp, same power band AND you dont have to wait on a turbo to spool to make that power. same for the non-turbo 7.3. but thats what also made both of them get about 8-12 mpg too. theres no doubt a psd pulls better than a non turbo 7.3 once the turbo is fully spooled up, but up until that point, the non turbo wins that one too.
while the non turbo 7.3 IDI was a horse in its day at no point will it pull with a PSD or a turbo 7.3 turbo IDI
A turbocharge 7.3 IDI will pull with a natural asperated 7.3 IDI until turbo spool the the turbo will walk away
oh yeah, theres no doubt about that. once the turbo kicks in any at all its not even close between the non turbo 7.3 and the psd. my family owns a wrecker business and we have pulled with everything from a 400 through the 7.3 psd in our pick up wreckers and roll backs. and the two we had the best luck with as far as pulling out from a stop were the 7.5 and the non turbo 7.3. they just seemed like they got the load moving the easiest. we ran that 7.5 until it had over 350k miles on it and still use it on the farm. thats one of the best engines we've had, i just wish it got better than 7 mpg.
Just curious, what's the tow rating on the Expy with the 3.73s??
(With heavy duty trailer tow option)
5.4L 17 in tires 3.73 rear axle ratio
Maximum GCWR 13,000 lbs
Maximum trailer weight 7500 lbs
5.4L 16 in tires 3.73 rear axle ratio 4x4
Maximum GCWR 13,500 lbs (13,500 for 4x2)
Maximum trailer weight 7900 lbs (8300 for 4x2)
Maximum frontal area of trailer is 5.6 square meters (60 square feet)
