3rd post
Old May 24, 2008 | 09:32 PM
geraldo14's Avatar
geraldo14
Tfi
I looked all over the distributor but there is no TFI module, I found an area below the cap that is rectangular in shape that is part of the distributor cast that looks like it could hold that module. I'll keep at this until it makes me go broke or insane!!
Jerry
Old May 24, 2008 | 09:59 PM
danr1's Avatar
danr1
<i.I looked all over the distributor but there is no TFI module, I found an area below the cap that is rectangular in shape that is part of the distributor cast that looks like it could hold that module.</i>
The TFI module is on the fender very near the firewall above the EEC connector on the drivers side on your truck.
Old May 24, 2008 | 10:02 PM
danr1's Avatar
danr1
Looks bigger as its mounted to a heat sink, need the same special tool to remove it from that heat sink that's needed to remove the distributor mounted module.
Old May 24, 2008 | 10:40 PM
geraldo14's Avatar
geraldo14
Tfi
Thanks, I'll check the firewall location tomorrow for the TFI module.
Old May 25, 2008 | 08:15 PM
geraldo14's Avatar
geraldo14
IAC Valve
Hey guys, I cleaned the IAC valve as suggested, it runs better than it ever has but not 100% yet. I think we're close, thanks again for the suggestions.
Jerry
teched
May 26, 2013 07:17 AM
viking89
16
Dec 22, 2010 05:39 PM
RC Dan
Nov 7, 2005 04:49 PM
Jerry Coll
New Member Introductions
May 19, 2005 05:59 AM
idaho_ford
Jun 2, 2003 08:37 PM
