truck wont start
Old May 21, 2008 | 09:22 AM
harleydude03's Avatar
harleydude03
truck wont start
truck wont start. it was running fine shut it off for about 45min. ccame back and allit will do is turn over. check fuses, fuel, and hpop resv. the hpop didnt have any oil in it, filled up tried to start the engine still just spins. what cause the hpop resv. to be empty? bad pump?
Old May 21, 2008 | 09:29 AM
F350-6's Avatar
F350-6
It's unusual for the HPOP to drain down that quickly. Is your engine oil full? Is the HPOP still full or is it empty again after the start attempt? Check the nut on the end of the IPR and make sure it didn't come off.
Old May 21, 2008 | 09:31 AM
harleydude03
engine oil level is good, so far the hpop[ resv. is still full.
Old May 21, 2008 | 09:42 AM
F350-6's Avatar
F350-6
Then make sure you check your batteries. Weak batteries will turn the engine what sounds like it's fast enough, but it's not. Maybe try and jump start it to see if that helps.
If that doesn't work you might try unplugging the ICP to see if there's oil in the plug or if it will start with it unplugged.
Old May 21, 2008 | 10:23 AM
harleydude03
thanks, i hadnt thought to check that, ill do it thus afternoon
Old May 21, 2008 | 11:52 AM
clintbonnie's Avatar
clintbonnie
You say you checked the fuel.. Did you check the fuel filter for fuel?
Old May 21, 2008 | 01:03 PM
floridadude's Avatar
floridadude
There is a recall on the cam sensor. That will make it stop,start sometimes or not at all. Worth looking into..
Old May 22, 2008 | 06:46 AM
harleydude03
new cps, and yes i checked and made sure the fuel bowl was full
Old May 22, 2008 | 08:41 AM
bkcowboss's Avatar
bkcowboss
You said the HPOP was dry and you left the truck running so it was sitting for just a short amount of time 5 minutes or so but had quit running? If so the reason your truck died is obvious, No HPO no injector firing, bu tthe reason the HPOP reservoir was dry needs to be addressed first. One of three things. Low engine oil (did that once with a real bad leak), faulty oil pickup line for the main engine oil pump, or faulty main engine oil pump. figure out why your HPOP res went dry then get it started again, it may take a while to get the air out of the system but it should at least run rough after a couple of cranks.
just another truck's Avatar
just another truck
Still no start?
Old May 23, 2008 | 07:53 AM
harleydude03
yea,still no start
Old May 23, 2008 | 08:46 AM
just another truck
i KNOW YOU SAID YOU HAD FUEL, sorry about the caps, but if you sdont have a fuel pump, to push it, will it drain out of the fuel bowl? have you checked the fuel pump
Old May 23, 2008 | 12:05 PM
clintbonnie
Did you check the fuel reset switch on the pass. side kick panel? It might be tripped.. Also, you said you checked the fuses.. did you check both under the hood and under the dash fuse boxes?
Old May 24, 2008 | 11:47 AM
harleydude03
still no start, got a guy coming with a scanner. hopefully he'llbe able to tell us whats up.
Old May 24, 2008 | 03:58 PM
harleydude03
got it scanned, showed p1280 icp out of range low. replaced icp and icp plug, still no start
