Sponsored by: Auxito
shocks
Old May 21, 2008 | 08:19 AM
00fordman16's Avatar
00fordman16
shocks
i have the oem shocks on my f 150 and i was wondering if that could be causing a slight vibraton in the rear. my truck has 130,000 miles on it and are rancho rs5000 a good shock? could bad shocks cause a slight vibration
Old May 21, 2008 | 06:57 PM
Bobby82490's Avatar
Bobby82490
No, a bad shock wouldnt cause a bad vibration.
Check your wheels to see if a wheel weight came off, also maybe check the driveshaft to see if a weight came off.
Old May 21, 2008 | 11:03 PM
jimm66's Avatar
jimm66
Bobby is right can't cause vibration, but I have the rancho's and I like them.
Check your wheel balance first.
Old May 21, 2008 | 11:52 PM
BLK94F150's Avatar
BLK94F150
Describe the vibration. Is it only when turning? Say like accelerating from a light and turning at the same time?
It sounds like limited slip chatter.
Mike
Old May 22, 2008 | 07:52 PM
00fordman16
when i speed up to 40 and let off the gas it starts vibrating and im not real sure its a vibration it might just be a rough ride i have had my wheels balanced, new u joints
Old May 22, 2008 | 09:16 PM
jimm66's Avatar
jimm66
Somewhere in the drive-line, or something loose in front-end?
Old May 23, 2008 | 06:04 AM
00fordman16
ok i found these rancho rs 5000 on summit and the fronts say they fit f150 including 7700 GVW and i have a 7700 series f 150 but the rear ones dont say anything about 7700GVW
Old May 23, 2008 | 12:10 PM
jimm66's Avatar
jimm66
Try Sam's Offroad Equipment-Your source for Warn Winch, Teraflex, Rancho, Service and Installation they usually have the best deal.
