screwy: question for you
Because I highly doubt you have fords breakout box here is what to do. Record battery voltage. Remove the connector from the ABS control unit (located on the driver side of the engine compartment) and jump pin 19 to 1 or 14. Then test the voltage between pins 17 and 1, or pins 17 and 14. To help I’ve included the following diagram. Also key must be on for this test.
My question is:
Where can I find this type of info for an 1996 E350 (its a motorhome). I'm getting abs code C1206, and have access to:
PINPOINT TEST G: REAR AXLE ISOLATION VALVE (CODE C1206 OR C1208).
The problem is that I don't have a breakout box. Can I do the pinpoint tests without one?
Thanks!
