Sponsored by: Real Truck
Changing out OEM crapolla shocks
Old May 20, 2008 | 09:09 PM
timcommon's Avatar
timcommon
Unhappy Changing out OEM crapolla shocks
I have had it with my local service guys telling me that my real jerky snap rolling moments when turning on a washboard road is, "Just the way it is". It did not do that in its first year of service.
And all is stock!
So I am ready to try Bilsteins, front and rear.
My question-
1. Is the removal and install straight forward or are there a few tricks I need to know about?
2. Also what torque value is appropriate?
Old May 20, 2008 | 09:13 PM
rebelyell618's Avatar
rebelyell618
it is pretty straight foward two nuts and bolts per shock.
the only trick i can say is use an impact gun every chance you can get to remove bolts when removing the factory shocks cause i spent quite a few minutes cussing at bottom bolts on the front shocks till i said forget it and borrowed my neighbors impact gun.
Old May 20, 2008 | 09:23 PM
dew the thunder's Avatar
dew the thunder
Yep... use an impact where applicable. The front bottom nuts have some kinda thing on them that you'll have to break off once you start gettin it loose.
Old May 20, 2008 | 09:28 PM
DCSpecial's Avatar
DCSpecial
Are you talking about the tab that is attached to the nut?
If so, that's so you don't have to hold the nut and can just spin the bolt out.
Old May 20, 2008 | 09:34 PM
dew the thunder
Oh... well for me it didn't serve its apparent purpose lol
Old May 20, 2008 | 09:49 PM
timcommon's Avatar
timcommon
Thumbs up Torque??
So what about the proper torque on these upper and lower bolts?
As a retired helo maintenance guy, this stuff is important to me.
Thanx
Old May 20, 2008 | 09:57 PM
Budman1962's Avatar
Budman1962
I put on bilsteins and it helped a lot. But the steering stabilizer made a huge differance. I put on a KYB steering stabilizer from shock warehouse and it is great. Handles so much better.
Budman
Old May 20, 2008 | 10:09 PM
jim042796's Avatar
jim042796
Slightly off topic - Budman, if I'm on a budget and I have to pick between the shocks or the stabilizer, which would you go with first? My truck is straight stock. Original shocks at 94,000 believe it or not. No visible leaks on the shocks. No stabilizer on the truck. It didn't come with one from the factory.
I know the shocks have to go. But which would you go with first? The stabilizer or the shocks?
Old May 20, 2008 | 11:17 PM
rebelyell618
Thanx
i dont know about everyone else i just tightened the bolt and nut till i couldn't turn it anymore by hand (reassembled with hand tools to prevent stipping the threads). then after 50 miles i made sure the bolts weren't loose, same for 50 more miles after that. once i hit 500 miles i checked again still not loose so i figured they were good to go. no problems till this day.
Old May 21, 2008 | 12:08 AM
zack7.3's Avatar
zack7.3
I usually do the same thing. Get it really tight by hand.
Old May 21, 2008 | 01:15 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Hit it with the impact until it doesn't budge but every few hits. Using my electric wrench to roughly that description, the torque stick measuered roughly 150 ft-lbs. Recheck after you put some miles on it, just like the lug nuts.
Old May 21, 2008 | 02:25 AM
rsmarcil's Avatar
rsmarcil
Looked it up for you.
Rear: Top nut 46 lb-ft
Bottom nut 66 lb-ft
https://www.motorcraftservice.com/pu...20/S6OMAIN.HTM
Front: Top nut 30 lb-ft
Bottom nut 59 lb-ft
https://www.motorcraftservice.com/re...e=EN&viewer=IE
Special thanks to ozx3+1 for the links to the workshop manuals.
Old May 21, 2008 | 07:39 AM
ffadragon's Avatar
ffadragon
Do both.
Bilstein Shocks = Expensive, but well worth it. About $250
Stering Stabalizer = Cheap, and well worth it. About $40
Both pretty easy to do. The shock are a little tuff because the are under very high pressure. A second person is very helpfull when putting the shocks on.
Old May 21, 2008 | 08:25 AM
Stone Mathews's Avatar
Stone Mathews
RSMARCIL, (And by association, ozx3+1)
Wow, great link! Do you have one for the early 1999 F-250 Super Duty 4X4 XLT 5.4L CC AT?
Thanks!
Stone
Old May 21, 2008 | 09:28 AM
rsmarcil's Avatar
rsmarcil
Stone, All credit goes to ozx3+1, not me. I just joined this site.
Here's a link to his thread https://www.ford-trucks.com/forums/7...p-manuals.html
Read that and thank him.
bexiga
2015 - 2020 F150
18
Nov 18, 2017 01:32 AM
swagfu
18
Mar 29, 2017 03:52 PM
OldSmith
Oct 12, 2016 06:38 PM
tcesni
Escape & Escape Hybrid
May 25, 2016 07:07 AM
Terryfromok
1983 - 2012 Ranger & B-Series
Apr 22, 2004 07:30 PM
