Sponsored by: Auxito
electrical question
Old May 20, 2008 | 08:30 PM
hoosierjm's Avatar
hoosierjm
electrical question
i have a 03 fx4. i pull a gooseneck horsetrailer. the plug is now in the bed. the center pin in the plug powers the 12 volt lights inside the trailer. it only powers when the truck runs or the key inaccessory.
can i do something that will power this pin all the time?
Old May 20, 2008 | 08:33 PM
rob188's Avatar
rob188
well doesn't your trailer have a aux battery?
Old May 20, 2008 | 08:34 PM
hoosierjm's Avatar
hoosierjm
re: battery
no aux battery
Old May 20, 2008 | 09:21 PM
rob188's Avatar
rob188
ohh ok, well then you would have to hard wire power to the trailer plug instead of it running off your ignition
rob188's Avatar
rob188
only problem with that being that it'll have a constant draw from your starter batt
Old May 20, 2008 | 09:28 PM
projectSHO89's Avatar
projectSHO89
You could pull the relay out of the box and install a jumper from terminal 30 to terminal 87. That would make the battery charge pin always-hot while still being fused.
Steve
Old May 20, 2008 | 09:33 PM
rob188's Avatar
rob188
there'd still be a constant draw but it would be protected by a fuse
