PATS info request
Old May 20, 2008 | 12:08 PM
bobmiers's Avatar
bobmiers
PATS info request
I have a 2000 F250 SD 4x4 7.3L XLT that I purchased used. (Build in KY in late 1999) I am about to install an aftermarket remote start/security system.
What I would like to know is: does it have PATS installed or not.
The reason for the question is that the truck has remote door lock/unlock & horn warning/locator. The keys we were given are the thin type (which I've always believed to be nonPATS). In my 1999 F150, (which had PATS ie thick keys) had a white plastic block below the steering column that had connections that ran up to the key location for the PATS sensor. The 2000 also has the same block. I haven't taken the steering wheel shroud off to visually inspect for a taped on key!
To further confuse me is the fact that this truck did not have factory wiring harness that contained the relay & resistor plug for the DRL.
Thanks.
Old May 20, 2008 | 12:10 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
The PSD Excursions have the PATS system. You are fine.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old May 20, 2008 | 01:09 PM
rbaker6336's Avatar
rbaker6336
no PATS on older SDs
Old May 20, 2008 | 09:54 PM
bobmiers's Avatar
bobmiers
PATS info request
Thanks for the info
Old May 22, 2008 | 08:04 AM
WH90's Avatar
WH90
no for some dumb reason ford didnt out that on the super duty but there on the cheap f150 xl, doesnt make any since to me, i heard revelco was great for securing your truck so it does not start or move, its not a alarm or nothin but it disables all the computers
Old May 22, 2008 | 08:31 AM
bobmiers's Avatar
bobmiers
I was also confused as to why a 1999 F150 would have the PATS and not the 2000 F250. Didn't make much sense. Also, note that the instrument cluster in my 250 is mechanical and the 150 was electronic. BTW, the 150 had the intermittent odometer problem (cold solder joint)that I was able to fix.
Old May 22, 2008 | 08:36 AM
just another truck's Avatar
just another truck
Boy I guess I am arrogant, I was trying to figure out what I asked for.....
Lemming
Electrical Systems/Wiring
Aug 28, 2014 02:55 PM
1998F150XLT
1997 - 2003 F150
Apr 12, 2013 12:00 PM
Rainmaker68
Jan 14, 2013 04:59 AM
2000V10USER
Jan 21, 2010 08:40 AM
jeffdoerr
15
Jul 22, 2007 05:19 PM
