Ford problems
Old May 20, 2008 | 01:11 AM
blackpatch's Avatar
blackpatch
Ford problems
I have a 95 f150 straight 6 and it has a blowen rear and front end. would i be able to put f250 front and rear ends in?
Old May 20, 2008 | 08:06 AM
Conanski's Avatar
Conanski
I gotta ask, how did you manage that? Are you sure it's not just a broken transfer case.
Old May 20, 2008 | 08:27 PM
G/T's Avatar
G/T
Hell Ya I Wanna Answer For That,front An Back, Look An Make Sure You Have Drive Shafts While Checking Transfer.
Old May 20, 2008 | 08:41 PM
blackpatch's Avatar
blackpatch
well hahah i tied a big chain to another truck and had a pull off..... back one blew.... so i took the back drive shaft off and put it in 4 and used the front tires hahhahaha they also blew....and im sure its not a transfer case becasue i took the plates off and the gears r all messed up.. lots of chunks of metal . so lol can i or cant i use the f250 ?
Old May 20, 2008 | 09:09 PM
rowdyredneck's Avatar
rowdyredneck
Front differential cases are interchangeable if the F-250 has the Dana 44 IFS. Axle housings are different though since the F-250 uses leaf springs versus the coil springs and radius arms on the F-150. The rear axle should fit, but you will be limited to 8 bolt wheels with the F-250 axles.
Old May 20, 2008 | 09:12 PM
flareside_thunder's Avatar
flareside_thunder
put F-150 stuff back in it and don't do anything stupid next time...rowdy is on the money...f-250 and up is leafsprung front.remember also there's a difference in the f-250 rears.......the ones with the big ugly hub stickin out are the ones to get.
JR
Old May 20, 2008 | 09:45 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
So, what exactly did you prove by having a pull off? What were you pulling backwards, an Abrams Tank?! You'll have less head ache by sticking with the stock set up.
Tim
Old May 20, 2008 | 11:09 PM
blackpatch's Avatar
blackpatch
i proved alot lol. the fact that i pulled the chevy alot more then he did. lol he blew his tranny and i lost my diffs... nothing big.. i just wanted to know if anything bigger would fit so it wouldnt happen that easy lol..
Old May 21, 2008 | 07:32 AM
tseekins's Avatar
tseekins
Attaboy!!!!
Tim
Old Jun 4, 2008 | 01:12 AM
TattooJim's Avatar
TattooJim
Ok
I know I'm a newbie. I'm not trying to be a dick; really. But if youre in the the ford truck enthuiast forum and you had a problem, how could it NOT be a "Ford Problem". I mean if we had a "Wife Problem thread" I could understand it but...well...you get it....anyway, yes I've had a couple of drinks, 'just caught me as funny..
Right on with the pulloff tho....
~ Jim
Old Jun 4, 2008 | 05:46 AM
gweeds's Avatar
gweeds
You know, as much of a waste as doing things like this is, sometimes you just have to... Like yesterday a guy down the street just made his own speed bump by laying sacks of asphalt across the road. So I called my friend over and we fired up the 86 diesel beater, and ran it over the speed bumps at close to 50 miles per hour. Nothing broke, but even if it did it would still be one of those priceless experiences...
