292 timing
Old Mar 1, 2001 | 06:33 AM
rudy's Avatar
rudy
292 timing
Can anyone tell me what the recommended initial timing is for a 292 and at what RPM to set it at? Thanks
Old Mar 1, 2001 | 09:55 AM
Kenny's Avatar
Kenny
292 timing
Rudy, My '59 shop manual shows the 292 initial timing to be set as follows: First, disconnect distributor vacuum line. Then set timing at 4 degrees B.T.D.C., with the engine idling below 550 rpm.
Kenny
Old Mar 1, 2001 | 10:02 PM
Mulletwagon's Avatar
Mulletwagon
292 timing
On an old engine it is usually recommended to set the timing where it runs best. I would start at 6 deg BTDC and than experiment by advancing two degrees at a time until it starts to ping and than back off accordingly. Too many variables to determine a hard number (gas octane, compression, valve timing retarded by worn chain/gears, etc.).
Old Mar 2, 2001 | 04:09 PM
BB's Avatar
BB
292 timing
