Starter
Old Mar 18, 2001 | 10:29 AM
tlak's Avatar
tlak
Starter
[font size="1" color="#FF0000"]LAST EDITED ON 18-Mar-01 AT 11:34 AM (EST)[/font][p]Will a starter from a 302 fit my 272? How do you identify between these V8s 272, 292, 312, 317, 341, 368? Im going by my data plate.
Old Mar 18, 2001 | 02:14 PM
tlak's Avatar
tlak
Starter
Wrote the starter question before I crawled under there, I know the answer. Still curious about engine ID.
Old Mar 18, 2001 | 11:35 PM
hpguy's Avatar
hpguy
Starter
As far as I know, the only way to tell is by stroke... Possibly by year as well
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Mar 22, 2001 | 07:06 AM
tlak's Avatar
tlak
Starter
Anybody have a starter?
Old Mar 22, 2001 | 09:08 AM
tlak's Avatar
tlak
Starter
Maybe I dont have as big a starter problem as I thought. Is there a sring on the starter shaft to keep the gear in the starter drive?
Old Mar 27, 2001 | 10:39 PM
Rosati's Avatar
Rosati
Starter
Tlak, I may have starter for you. Email me
Krosati(No Email Addresses In Posts!)
Old Mar 27, 2001 | 11:49 PM
darkman's Avatar
darkman
Starter
NO RINGS but there is a pin behind the spring. Lightly compress the spring in a vice until the pin is visible and clear on both sides. Push the pin through just enough to clear the shaft so that the drive will slide off. Push the pin back in enough to ensure that the spring wont come off. That is it! Reassemble in reverse order. When you put a new drive on and test the starter the drive will spin in to the crank position and not return as it requires the engine to overspin it for a return. This is not a problem and as soon as you crank it it will return to the rest position.
Thanks Charles
Old Apr 3, 2001 | 12:41 PM
darkman's Avatar
darkman
Starter
newguy399
13
Mar 15, 2015 07:16 PM
Rmc292
25
Jul 5, 2013 11:13 PM
Lance Hogan
21
Sep 6, 2010 11:35 AM
tlak
Sep 4, 2009 09:27 PM
peterbond
Feb 20, 2002 08:00 PM
