Super chip error codes
Old May 19, 2008 | 08:56 AM
smith782134HCP12's Avatar
smith782134HCP12
Hi;
I have an 02, 7.3 X and installed the Super chip yesterday. The throttle is now very responsive which makes me think the timing has advanced which is a positive as I am after the fuel economy. It does have the ability to scan for codes and I am getting two back.
The first “Exhaust Back Pressure Sensor Error.”
Second “Int control mod kam error”
Can anyone tell me what these mean and if they are critical?
Thanks, Smitty.
Old May 19, 2008 | 09:20 AM
PLC7.3's Avatar
PLC7.3
Sorry wrong area this NON computer driven engines........ move up to newer trucks.
99-2003 Power Stroke.................
Old May 19, 2008 | 09:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Moved to 1999 to 2003 Power Stroke forum.
Old May 19, 2008 | 09:40 PM
big poppa's Avatar
big poppa
Your going to get that kam error because of the chip, no worries, i got the superchips handheld and i get it too. Second, your ebp tube might be clogged with soot, take off and clean it out.
Old May 19, 2008 | 10:22 PM
smith782134HCP12
Thanks much. I'll go ahead and take care of that.
Old May 20, 2008 | 01:11 AM
big poppa's Avatar
big poppa
O yea, welcome to FTE. Be careful with the sensor, don't poke anything to far up there, it has a little rubber diafram up there. Clean the tube wd-40,bp blaster, run weed wacker line through it to break up the soot, blow it out (the tube) good and install.
Old May 20, 2008 | 09:24 AM
smith782134HCP12
Egr
Any chance of a photo of the both? Under the hood I see a lot of turbo charges, after coolers, afterburners, vectoring nozzles.... (I used to think I knew it all!) If not I will go digging around and if totally lost I can do a photo search or a manual.
Old May 20, 2008 | 09:25 AM
smith782134HCP12
Or if I knew where it lives, that would help also.
Old May 20, 2008 | 09:27 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here you go, read this and you should be good to go. clicky here
Old May 20, 2008 | 10:02 PM
smith782134HCP12
Error code
That's what I needed, Thanks. Spent most my life with big commercial oil burners but with the help of the forum I'm getting to find my way through the woods.
Thanks again for your time and help.
Smitty.
Guess I should get a good manual also.
Grinder Man
Oct 10, 2014 09:35 AM
whitetrash
Bronco II
May 30, 2008 08:17 AM
Lugnut2008
Modular V8 (4.6L, 5.4L)
Nov 9, 2007 01:57 PM
TireSmoke
Computer Chips & Tuners
Mar 22, 2007 06:05 PM
Dominater
Apr 27, 2005 04:44 PM
