So I'm changing the front brake pads on my 97 Expy and notice the front sway bar is disconnected! I cant beieve I didnt notice this before. This happen to anyone else?
sway bar links from for have a tendency of snapping in half. I have gone 2 sets under warranty. Now that i am out of warranty i finally use a kit from NAPA and they have lasted longer than the ford OEM.
I have replaced both sides twice now. The second time I greased up the inside bolt before installation. The bolt corrodes bably and breaks. If I had seen the aftermarket pieces I would have bought them instead of the OEM. The OEM parts hold moisture and promote corrosion.
Threaded rod is only grade 2 hardware. It is not strong enough to take the stress place on the sway bar end links. Plus you do want a smooth surface for the bushings to ride on, not a threaded one.
Need advice from those who've done this - recently noticed I have to replace both sets of sway bar links - top bushings are gone and not connected on either side. Just picked up aftermarket parts but not sure how to remove old/broken links. Rust seems to have frozen bottom nut to threaded rod. Wrenching from the bottom only spins the top end, even when grabbed with a pair of vise-grips.....Since kit has all new links, top/bottom bushings and washers/nuts - can I just snap off the old ones? Suggestions?? Thx.
Yeah I also had a hard time removing the lower nut, but I managed to remove it using the right sized socket and a pair of vise grips. Try to grab the bare metal instead of the rubber surround on the link and tighten your vise grips really tight. If you can manage to snap off the links without damaging the sway bar itself then go for it cause you wont need to use any of the old equipment anyways. Also try spraying the rusted bolts with some penetrating oil and letting it sit, then try it again. Good Luck
