Y-Block ID#'s
Old Apr 30, 2001 | 12:40 AM
57f100man's Avatar
57f100man
Y-Block ID#'s
Can anyone help me with the ID#'s on my Y-Block Heads and Manifold please?
The manifold has the #'s 62Y and ECG-9425
The heads have ECZ-A and 63M
Any assistance would be most welcome.
The vehicle is a 57 F100, I hope to have the block #'s and diff #'s soon. Thanks from Ashley. (-:
Old Apr 30, 2001 | 12:33 PM
Nate_64's Avatar
Nate_64
Y-Block ID#'s
ECZ-A heads in 57-58 are for a 272 but have the big (1.92") valves and are from a heavy-duty truck. If the heads are from 56 they are 272 1.78" valve heads from a pickup. Or, if you're really lucky, the same code was used on the heads of the 56 312 Police Interceptor. I don't know what the 63M stands for- maybe someone else will.
The 272 was the common engine in 57 pickups- but your engine may have been transplanted. When you get the block casting # it will help you know for sure.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Apr 30, 2001 | 07:13 PM
57f100man's Avatar
57f100man
Y-Block ID#'s
Hi again and thank you Nate, I have those block #'s now.
Looking from the front of the engine, on the left hand side,
closest to the front there is 60R:3 behind that there is the
#19 then back further to ECG60150, then further back there is either #99 or #66 then at the back still on the left hand side is #33.
On top of the block next to the distributor is the letter F under that is ECG and under that is 01.
I hope someone can help me out, thanks.
Ashley.
Old Apr 30, 2001 | 11:34 PM
Nate_64's Avatar
Nate_64
Y-Block ID#'s
ECG means that it is a 272 used in cars and trucks from 55-57. The location of the casting number as you descibed it indicates that it was likely cast in the Dearborn, MI plant. Most Dearborn blocks were used in trucks. All of this info means that there is a good chance that you still have the original motor in your 57 F-100.
By the way- I'm just passing along info I found at http://www.ford-y-block.com/
There is some good, detailed info about y-blocks to be found there.
Nate
1990 F-150 5.8L
Old May 2, 2001 | 06:57 AM
57f100man's Avatar
57f100man
Y-Block ID#'s
I have the engine #'s now and they are as follows, from the front of the engine down the left side there is 60R:3 then back to 19 and behind that is ECG60150, further back is 99 or 66? then a little further back there is a 33, on top of the block next to the dizzy is F under that is ECG and under that is 01.
I hope some one can help me out, thankyou. From Ashley
Old May 4, 2001 | 06:35 AM
57f100man's Avatar
57f100man
Y-Block ID#'s
Thank you Nate, I suppose it is'nt that bad having a 272, maybe I will get some good gear for it. I will have a look at that web site that you mentioned, thanks for all your help.
From Ash.
Old May 4, 2001 | 09:38 PM
hpguy's Avatar
hpguy
Y-Block ID#'s
LEO56F100
Jan 7, 2020 04:15 PM
Cobwebman
Jun 12, 2016 12:36 AM
Scout Pilot
Apr 2, 2012 09:09 PM
DGMFORD
13
Oct 24, 2004 06:23 PM
joanne
Aug 6, 2000 09:57 PM
