Sponsored by: Auxito
Star wheel stripped
Old May 19, 2008 | 04:31 PM
oldgoat49's Avatar
oldgoat49
Star wheel stripped
Boy was wanting to put rear brakes on his 97 F150 with drums. Pulled the plug and it appears that the star wheel is stripped and won't allow me to back off the brakes to get the drums off. Any ideas on getting the drum off?
Old May 19, 2008 | 06:47 PM
screwy's Avatar
screwy
I’d use a wheel puller, or a dremel to make some new grooves.
Old May 19, 2008 | 07:09 PM
sheetsd66's Avatar
sheetsd66
Spray it with some Blaster or WD-40 and try to back it off anyhow. It may take a minute or two, but you'll eventually get it. Or you can grab the gear puller and pry it off. The shoes will grab and won't want to give it up, but the insides will come loose if you pry hard enough.
Old Jul 28, 2008 | 11:54 AM
pgc7299's Avatar
pgc7299
Stupid question...When backing the star wheel off do you go up and toward the outside or down and toward the inside ?
wagon burner
1983 - 2012 Ranger & B-Series
Jun 5, 2012 04:37 PM
jsutton
General Automotive Discussion
15
May 23, 2009 02:02 PM
cjben
Oct 24, 2005 12:05 PM
Ford_NDN
Sep 8, 2004 02:26 PM
RabidJade
Oct 23, 2003 12:37 PM
