Steering box adjustment?
Old Aug 26, 2003 | 04:01 PM
Michael Sizemore's Avatar
Michael Sizemore
I have lots of play int he steering wheel! The steering box seems to be free from severe leakage etc... Is there grease fittings on it? DO ue regular grease in the fittings??
How do I adjust this???
Old Aug 26, 2003 | 04:27 PM
mt78Lariat's Avatar
mt78Lariat
there is an adjustment,, you should consult a front end alignment shop to adjust this because if you adjust it too tight you can damage the steering box.
Old Aug 26, 2003 | 05:20 PM
pro3qtr's Avatar
pro3qtr
Sounds like the box is wore out, there is NO adjustment on a gear box for looseness.
What U see is the bearing preload when the box was new.
Old Aug 26, 2003 | 08:59 PM
skuteman's Avatar
skuteman
jackup the front end of your truck and try moving either front wheel left to right and back. See how much play is in the movement.....probably alot. Check the draglink...the steel rod connected to both front wheels and see if it has any play at each point of attachment . it looks like a pool cue for a Sumo wrestler. While you got it jacked up......locate the steering shaft that connects the steering wheel to the steering box......inspect the "rag joint" . have a friend turn the steering wheel lock to lock and see if you can observe any play in the rag joint. with the hood up obviously!!! you may need to replace it. happy hunting...sk
Old Aug 27, 2003 | 09:44 AM
beartracks's Avatar
beartracks
You can tighten down the preload a tad, maybe 3/8 turn. If the box is worn out it wont hurt and might help for a while but like was said check the tie rod ends. Squeeze them with a large pair of adjustable pliers. There shouldn't be any free movement when you do.
Old Aug 27, 2003 | 12:38 PM
Seabeetough's Avatar
Seabeetough
-Edited for off topic content-T1
newguy399
Dec 19, 2013 09:54 AM
rwkinch
Dec 18, 2012 04:17 PM
sammie0126
Nov 29, 2012 03:50 PM
BigBlack6L
Oct 22, 2008 04:43 PM
JohnAW
1983 - 2012 Ranger & B-Series
Feb 22, 2005 08:05 AM
