brakes going out?????
Old May 18, 2008 | 01:17 PM
honeyb's Avatar
honeyb
my excursion just started pulling the steering wheel to the right a little bit when you touch the brake???
is this an indication the booster could be going out?
Old May 18, 2008 | 01:26 PM
1996pwrstrk's Avatar
1996pwrstrk
Sounds like you may have a caliper hanging up ,you need to check it out it could even be a broken brake pad. I even had a small stone caught between the rotor and the pad that caused a bad pull.
Old May 18, 2008 | 01:30 PM
honeyb's Avatar
honeyb
thanks , i hope that is what it is, i am hauling a trailer today and do NOT want to lose brakes, but i need to get home
Old May 18, 2008 | 01:37 PM
1996pwrstrk
It could even be your caliper pins hanging up . Be carefull , watch you don't over heat the one that is dragging.
Old May 18, 2008 | 02:47 PM
cangim's Avatar
cangim
Could also be the ball joints on that side. Before replacing mine, it would pull to the right because the geometry was changing at the lower ball joint. Now I stop nice and straight.
Old May 18, 2008 | 03:08 PM
jhand124's Avatar
jhand124
If your caliper is hanging up and you drive a good distance, it's likely that the rotor will be toast. I speaking from experience I have done it more than once.
Old May 18, 2008 | 03:31 PM
camodown's Avatar
camodown
My slide pin was seized and would occasionally pull... Fixed it and all is well
Old May 19, 2008 | 04:01 PM
rustydailey's Avatar
rustydailey
Not to hijack, but mine is doing the samething but I have replaced the slide pins.
Old May 19, 2008 | 04:40 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is how to grease your slide pins. clicky here
Albert_f100
Mar 22, 2014 07:05 AM
neilc88
Jan 14, 2011 06:11 PM
FixinaSixtySeven
Aug 22, 2003 05:55 PM
Raintree55
Mar 8, 2003 04:49 PM
dgb2002
Jan 8, 2003 08:04 AM
