Duraspark module, I6 vs V8?
Old May 17, 2008 | 10:25 PM
m000996's Avatar
m000996
Quick question, is there any difference between a Duraspark module from a straight 300-6 and a V-8? I had a working Duraspark handed to me from a '79 with a 300-6. Any reason why it wouldn't work in my '75 360FE? I'm going to go try it out and swap the units to see, but I thought I might ask first.
Thanks, Mike
Old May 18, 2008 | 07:13 AM
teds74ford's Avatar
teds74ford
I think the color is the only thing that matters.
Old May 18, 2008 | 07:53 AM
Drac's Avatar
Drac
Save the old ones
I don't think there is any difference between the 6 and the 8. But there are two different Duraspark units; a 2 wire plug and a 3 wire plug - the plug that goes to the trucks wiring harness. The other plug (4 wire) going to the distributor is the same for both.
Shawn
Old May 18, 2008 | 08:26 AM
80broncoman's Avatar
80broncoman
Should be just fine. Both should use the same part number replacment module.
Old May 18, 2008 | 10:15 AM
fmc400's Avatar
fmc400
MSEE
As long as the colors of the wire grommets match, it is OK.
Old May 18, 2008 | 01:20 PM
montana_highboy's Avatar
montana_highboy
Shawn
The 7 wire module is the Duraspark I from '74-'75, the 6 wire module is the Duraspark II from '76 up, Ford deleted the blue wire in the later Duraspark II units.
Old May 19, 2008 | 02:31 PM
fordophile's Avatar
fordophile
but they still swap...?
raven3
Jul 22, 2014 09:45 AM
willowbilly3
15
Feb 12, 2013 04:36 PM
JMC302
Sep 28, 2007 10:09 AM
lrd56
Electrical Systems/Wiring
Sep 16, 2004 08:10 PM
