running problems.
Old Jan 19, 2002 | 03:04 AM
kyla64's Avatar
kyla64
running problems.
I have been trying to get my 64 f100 292 running and have run into manny manny problems i got most fixed not i just have to play with the carb. i was told that if i want to properly adjust the carb turn both adjustmen needles down all the way and back off a half turn i tried that and it wont idle if i turn them up more it idles but floods and puts out white smoke. is that the proper way to do that or do i have more problems. The only thing i Havent done now is harden the valve seats or alternator and intake manifold and carb and distributer. so iam just at a lose i have been working on this problem for about a month on my own and finally need help so i can start driving it.
Also i have a weird cooling system problem. What is the proper way to airate the cooling system? i check all my lines and they all have coolant in them i crack the valve ontop of the manifold it has water the radiators full but when ever i get the engine to operating temp. or around 180 the radiator starts flexing and (belching) everyone seems to think its normal untill they see it. its almost enough to bust the coolant resevoir. also i cant seem to get any hot coolant through the heater core lines. and have two odd coolant lines coming out of the sides of the block that go to a t and then a small box on the tranny another line comes of the box and goes to the water pump. no one i talk to even has a clue as to what this is. any ideas?
Old Jan 19, 2002 | 02:10 PM
Rosati's Avatar
Rosati
running problems.
First warm the engine by taking a run to the store and get a 6-pack of your favorite beverage. Then hook up a tach to the engine. Lower the idle speed to the slowest RPM it will sustain an idle at.
Now turn one of the mixture screws clockwise until the engine stumblest (count the # of turns just in case), then reverse the rotation to obtain the highest RPM possible. Lower the idle speed again and repeat for the other side. Do all of this with the choke off, and the air cleaner on.
[b]I cannot visualize your hose configuration, but the radiator cap need to go and replace with a new one. Purging the air out of your system is simple. Drain the coolant and flush the system with Prestone or the like and refill according to the instructions. Once the rad. is full, run the truck with the cap off and the heater on. Watch the radiator opening. When the thermostat opens, your coolant level should drop and you should see it circulating. Top it off while its running. Do not overfill. The coolant level should only be about an inch above the core. Your cap doesn't seem to be venting that's why your radiator is swelling and will start leaking soon. The heater core is simple to check for a valve on the passenger side fender apron. If it's closed or broken you will need to replace it. Otherwise, remove the heater hoses and try flushing the core by itself. It may be clogged.
Krosati
[link:www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=28|My User Gallery]
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Jan 19, 2002 | 11:31 PM
kyla64's Avatar
kyla64
running problems.
i have replaced the radiator cap already. the only thing i havent done is clean out the hoses radiator that funny box in back and the heater core. what would be the advantage of a flush if everythings already been hottanked? just for the radiator and hoses? when i leave the heater on. i think on pulling the **** out is on right?anyway when i leave it on and get it up with the cap off it starts shooting water out. and the belching is worse than with the cap on. thank you for the carb tuning tips i will accomplish doing that tommorow when i get the other rocker shaft on.
Old Feb 13, 2002 | 08:46 PM
57_ford's Avatar
57_ford
running problems.
The thermastat could be stuck shut. Has the motor been apart reacently?
Old Mar 18, 2002 | 10:47 PM
jds1971's Avatar
jds1971
running problems.
First of all- let's get back to basics
If your truck is blowing white smoke, you may have an internal coolant leak. A rich fuel mixture won't be white. No amount of carb fiddling will help any. If you are experiencing belching from your cooling system at the same time- again, I would have to say you have an internal coolant leak. Maybe as minor as a gasket or block or head could be cracked.
As for that box on the tranny, believe it or not, that used to be a primitive type of transmission cooler that used coolant from your cooling system if I remember correctly. I've only seen them on automatics.
Just something to think about
Joe
Old Mar 20, 2002 | 08:17 PM
FOMOGO's Avatar
FOMOGO
running problems.
Old Nov 23, 2008 | 06:29 PM
Arno F100's Avatar
Arno F100
The little box is an oil cooler for your ford-o-matic for sure.
My truck also has one.
Old Nov 23, 2008 | 07:37 PM
46yblock's Avatar
46yblock
Arno, this thread is 6.5 years old!
Old Nov 23, 2008 | 07:46 PM
Arno F100's Avatar
Arno F100
yes i saw it too sorry
just looking for 3x2 info
Old Nov 23, 2008 | 08:44 PM
46yblock's Avatar
46yblock
Maybe some of the posters will pop back into the forum.
2006powerstroke90
Apr 1, 2017 09:54 PM
swolh
27
Feb 8, 2015 10:45 AM
bigstakn
Jan 16, 2014 04:49 PM
mb1096
Sep 3, 2011 12:36 AM
guitar_199
1997 - 2003 F150
Oct 18, 2010 07:34 PM
