steering column problems
Old May 17, 2008 | 04:32 PM
gamehunter69's Avatar
gamehunter69
have a 1997 F250 w/tilt strg. no air bags. Need picture diagram of re-installation of upper brg. and spring. I am unable to get to a dealer for diagram at this time. I have removed all worn parts which were very worn or broken. I would appreciate any help with this matter
Old May 17, 2008 | 06:09 PM
Cuda_jim's Avatar
Cuda_jim
Install steering column bearing tolerance ring and steering column bearing sleeve over steering shaft to upper steering column bearing. Pict 1
Install steering column upper bearing spring and new bearing retainer on top side of bearing spring using a 3/4-inch I.D. by 2-1/2-inch long PVC pipe Pict 2
Install turn indicator cancel cam, flush surface up. No pict
Old May 23, 2008 | 02:53 PM
gamehunter69
Jim, Thank you very much! I just got home from out of town and found your message. It is very helpful, look forward to future questions or help that I may be of assistance.
Again, Thank you!
Ruben
Old May 23, 2008 | 03:40 PM
tjbeggs's Avatar
tjbeggs
Nice Job Jim!
Old May 23, 2008 | 10:28 PM
Aireeek's Avatar
Aireeek
Damn Jim..You da man!!!
Old Sep 9, 2008 | 06:43 AM
dadoftwo's Avatar
dadoftwo
I have the same truck with the same problem. Thanks for the information.
How can I tell if I have an airbag?
Old Sep 9, 2008 | 07:05 AM
tjbeggs's Avatar
tjbeggs
If you have a 250 or 350 you don't have airbags
Old Sep 9, 2008 | 07:20 AM
dadoftwo's Avatar
dadoftwo
Thanks man
Fordranchero
Nov 17, 2012 05:16 PM
scooter53147
Jun 17, 2011 12:25 PM
pacoustic
Mar 16, 2006 09:50 PM
pizalm
Jul 19, 2004 10:40 PM
edgarpoe27
Jul 26, 2002 11:46 PM
