92 Super Duty Steering Components
Old Nov 17, 2012 | 12:52 PM
Fordranchero's Avatar
Fordranchero
I'm trying to get a diagram of the steering parts for my 92 Super Duty, the tie rod ends are getting worn but I seem to get different references to which is inner or outer and whether the parts can be separated.
Seems to make a big difference in cost.
The passenger side end is worn out and appears to thread into the link but the parts guy says I have to buy the entire assembly.
One parts house calls it an inner and another calls it an outer.
Got to fix it soon as it's eating up tires.
Old Nov 17, 2012 | 04:36 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
do you plan on keeping the truck for a year or more?
if so,it's probably just best to change them all at once,since you'll need a front end alignment after the job.if you replace only whats bad right now,then the others fail shortly after,then you'll have them anyway and pay for another alignment.
if you can only afford to do whats needed,then you don't have much choice of course,but it's something to consider if you plan on keeping the truck.
Old Nov 17, 2012 | 05:16 PM
Fordranchero
I understand that reasoning but the truck only has 60,000 miles on it and the other parts are tight.
Seems premature to me, the rubber boot has been cracked for a long time though.
The damn thing has no grease fittings so , yeah the others will eventually fail but, a twenty year old truck with this mileage, it's going to be a long time before the other ends need replacing.
So, back to the original question, does anyone have a parts breakdown for the front end on this truck?
rhoward
Oct 16, 2009 05:51 PM
Max66
Offroad & 4x4
Oct 28, 2007 12:29 PM
moto_stevo
Sep 23, 2007 06:27 PM
WinterRoad
May 20, 2007 11:20 PM
rosa70
Nov 16, 2005 02:06 PM
