DPFE sensor help on a 1995 4.9L
Old May 17, 2008 | 04:16 PM
vellicate's Avatar
vellicate
I have a 1995 f150 with the 4.9L L6.I'm trying to locate to position on the DPFE sensor but can't find it. Anyone have pictures or a Diagram I could use.Any help is greatly appreciated.
Old May 18, 2008 | 07:53 AM
EPNCSU2006's Avatar
EPNCSU2006
Your truck might not use a DPFE sensor. The EGR valve is located just behind the throttles -- if it has a sensor on the valve itself, there isn't a DPFE sensor. If there is a DPFE sensor, there will not be a sensor on the EGR valve itself, and if you follow the EGR feed tube, there should be a pair of small rubber hoses leading to the DPFE sensor.
Old May 18, 2008 | 07:46 PM
Silver Streak's Avatar
Silver Streak
What he said. The 4.9 with a DPFE is fairly rare. If I had to guess it would probably have only been used on California models in 95.
Old May 19, 2008 | 11:28 AM
vellicate's Avatar
vellicate
Thanks for the help. I thought I had one. next question, I have something that looks like dpfe sensor. it's located directly below the egr valve, mounted on the left side of the cylinder head.It has a connector and 2 vac lines.one goes directly to the egr valve (which does have a sensor on top of it) and the other goes to the intake manifold on the right side.any clue to what this is?I'll post some pictures later when I get out of work. Kinda confused me into think I had a dpfe.also the connector is a 2 prong unit. I really hope i don't have to replace the egr valve on this thing, looks very rusty..
Old May 19, 2008 | 12:12 PM
Silver Streak
That's the EVR solenoid. That stands for EGR Valve Regulator and it looks nothing like a DPFE sensor. There should be one or two more just like it in the same area.
If you'll tell us what your problem is instead of throwing out shots in the dark we can help you more efficiently.
Old May 19, 2008 | 12:14 PM
44dwarf's Avatar
44dwarf
The box under the valve is likely the vaccum solinod vavle it is controlerd by the sensor on the top of the EGR.
Old May 19, 2008 | 07:16 PM
vellicate's Avatar
vellicate
Ok, my problem is a check engine light, which I pulled codes for monthes ago and got 2 egr codes.One was a flow code, other was a voltage.I'm also expirencing poor fuel economy, sluggish performance, and trans shifting hard.
I was looking into getting a new EGR valve and read something about the DPFE sensors going bad a lot more then the valve.I called a local ford dealer and they confirmed what I read.So that's how I got here.
Old May 19, 2008 | 09:47 PM
Silver Streak
OK, that's what we need to know. Chances are that the EGR position sensor is going or gone. What happens if you connect vacuum to the EGR valve with the engine idling?
Old May 19, 2008 | 10:09 PM
vellicate's Avatar
vellicate
I installed a new EGR position sensor 2 days ago with no change in performance or shifting.not so sure on fuel economy yet. But before I replaced the sensor, the check engine light was very intermittent, coming on for only 5-10 seconds at a time.now the check engine light comes on solid after 1-2 minutes of driving and stays on until the key is shut off...
Old May 20, 2008 | 08:56 PM
vellicate's Avatar
vellicate
any thoughts? or suggestions?
Old May 20, 2008 | 09:09 PM
quicklook2's Avatar
quicklook2
read the codes.
SteelHorse4x4
Apr 9, 2017 12:12 AM
GreaseGun Joe
Oct 15, 2015 04:44 PM
carlakally
New Member Introductions
Apr 23, 2013 03:19 PM
deejdeej
1983 - 2012 Ranger & B-Series
Jun 10, 2010 09:51 PM
