tow/haul button
Old May 17, 2008 | 05:42 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Originally Posted by superman724
im towing two jet skis so say less then 5000lbs
O well then you defintaly dont need to turn of over drive.
Old May 17, 2008 | 11:38 PM
superman724's Avatar
superman724
good to know thanks
Old May 18, 2008 | 06:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Monsta
They have a separate controller that is compatible with my truck?
Not that I'm aware of. You can't just swap PCMs, the wiring is completely different. You'll need to swap the complete engine and trans harness, and then there may be issues with connecting that wiring and PCM to your truck. If they are not compatible things may not work, such as your instrument cluster.
That's why I considered one from an existing 2V powerplant in case I had to swap PCM. I could always add a custom tune so that I wouldn't have my truck "de-powered" running the PCM from the E-series.[/QUOTE]
Old May 18, 2008 | 02:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds like I just need to be happy with what I have then.
Jim McCann
Oct 14, 2015 01:27 PM
MooSSe
All Things Towing
19
Jun 12, 2015 10:30 PM
rowekmr
Mar 23, 2015 08:11 AM
swimmer_spe
All Things Towing
15
Aug 13, 2013 06:33 PM
Rockie5
May 31, 2008 08:15 PM
