Sponsored by: Auxito
2003 super crew ford problems
Old May 15, 2008 | 11:42 AM
william55am's Avatar
william55am
2003 super crew ford truck have electrcial problm with all dash gauages and power in truck. at start up in morning the gauges and lites blink off and on at will till truck runs about 45 mins. then all starts working with no problems till next day . some one please help thanks.
Old May 15, 2008 | 11:52 AM
92merc's Avatar
92merc
If you're seeing the gauges sweep all the way to one side, then back, it's usually your battery going bad. Could be alternator I suppose not charging. But usually it's the battery.
Old May 17, 2008 | 02:21 PM
rebelkgh's Avatar
rebelkgh
I agree with 92merc, You may also want to check your ground connections. Over time corrosion will prevent a proper connection. Another simple check could be the fusible link on the positive wire by using an ohmmeter. I have had instances where a vehicle lost electricity gradually because of a deteriorating fusible link or wire. As always try the simple things first before digging into costly repairs.
