Sponsored by: Innova
Help stuck
Old May 15, 2008 | 06:06 AM
rickkk's Avatar
rickkk
Help stuck
Hi All,just bought an 04 F-350 S.D. and want to remove stock radio...I bought the removal tool and short of using the chainsaw I cannot get this thing out! The tool Seems to make a click on the right side but not on the left. Any Ideas? Thanks Rickkk
Old May 15, 2008 | 09:53 AM
bgalaxy67's Avatar
bgalaxy67
It's a pain in the rear.
The sides are spring loaded so you have to push outwards away from the deck as you pull the deck out. The tool can slide in too far making it harder to get the deck out. It takes a little practice but once you get it out the 1st time, every time after that is easy.
Old May 15, 2008 | 08:51 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Be patient with it and jiggle the tool on the slide that aint clicking... its a pain like bgalaxy said... Just be patient with it... Occasionally some force is needed... Just not a whole lot...
Old May 15, 2008 | 09:45 PM
bgalaxy67's Avatar
bgalaxy67
All else fails.... Use a big hammer.
Old May 15, 2008 | 10:17 PM
Truckin4life
no no no... its when all else fails... get a BIGGER hammer!!! lol... I dont suggest jumping straigh to a 32lb sledge though...
Old May 21, 2008 | 04:04 PM
rickkk's Avatar
rickkk
mission completed
Thanks all,I ended up prying out the 4 WD panel and finding the left tabs were bent back too far for any
tool to move them,Icut them off!!!! that was alot of fun,It decided to come out then. Thanks again for the input. Rickk
Old May 22, 2008 | 03:05 PM
Beerstalker's Avatar
Beerstalker
Wow, you shouldnt have had to cut them off. You could have just pulled the whole dash panel out with the radio stuck to it. I had to do that in my 99 and it worked ok. Once the dash panel was out it was pretty easy to release the clips on the stock radio.
Old May 23, 2008 | 04:33 AM
rickkk's Avatar
rickkk
I guess I sometimes get too focused on things to see another way. Later Rickk
rickkk
Sep 18, 2012 11:16 AM
rickkk
Nov 25, 2011 06:37 AM
rickkk
May 6, 2009 12:21 PM
rickkk
May 28, 2008 05:58 PM
rickkk
Dec 2, 2007 05:48 PM
