Changing glow plug harness
Old Nov 24, 2011 | 01:27 PM
rickkk's Avatar
rickkk
Hi all, fixing to change out both glow plug harness's. Question is what all do I have to remove to do so? Also time required? Thanks Rick
Old Nov 24, 2011 | 01:33 PM
brickie's Avatar
brickie
What year is the motor?
Old Nov 24, 2011 | 03:11 PM
rickkk's Avatar
rickkk
Well after looking in all the suggested places with no luck,the tag is missing on top of the FICM . I cleaned the back of the block and was able to half way make out the numbers...what a dumb place to put it. they are best guess, 6.0H020615711 If its any help the ICP sensor is located in the valve cover passengers side. Thanks Rick The truck is an 2004
Old Nov 24, 2011 | 08:18 PM
texans's Avatar
texans
Drivers side remove air intake system then unplug harness. On the passenger side it would be easiest to just remove the inner fender well to get access to the harness.
Old Nov 24, 2011 | 09:13 PM
bismic's Avatar
bismic
"Glow plug harnesses - passengers side:
For vehicle build date is 01/15/04 or later" 4C2Z-12A690-AB
"Glow plug harnesses - drivers side:
For vehicle build date is 01/15/04 or later" 5C3Z-12A690-A
Old Nov 24, 2011 | 09:17 PM
brickie's Avatar
brickie
Mark filled in the reason I asked the year.The early trucks have a resusable buss bar the later ones it's best to replace the harness.
Old Nov 24, 2011 | 09:21 PM
bismic's Avatar
bismic
Hey Tony - Holiday geetings from down South!!
Old Nov 24, 2011 | 09:44 PM
brickie's Avatar
brickie
Back at ya Buddy!
Old Nov 24, 2011 | 10:33 PM
m-chan68's Avatar
m-chan68
'04 engines are always a lot of fun to look up parts for. NOT!!!
Old Nov 25, 2011 | 06:37 AM
rickkk's Avatar
rickkk
Thanks Scotty,Mark &Tony. Seems easy enough. ....Rick
Splash67
Apr 3, 2014 09:34 PM
tracyclifton
Jun 3, 2012 11:10 PM
jmcotski
Jan 19, 2012 10:08 AM
rickkk
Nov 22, 2011 12:56 PM
exiled
Jun 29, 2011 04:12 PM
