diff fluid
Old May 15, 2008 | 03:35 AM
mejonz's Avatar
mejonz
diff fluid
anybody know how much limited slip additive to put into a dana 70 rear axle going to replace the rear brakes this weekend and replace the fluid in the diff while I'm at it .
thanks
Old May 15, 2008 | 05:14 AM
PLC7.3's Avatar
PLC7.3
May find what you want here........
The Expert - Librarian - Information for driveshafts, u-joints, axles, heavy axles, light axles, Driveline
Old May 15, 2008 | 10:35 AM
haroldrussi's Avatar
haroldrussi
I use a lube which is rated for limited slip, already has additive in it....
Old May 15, 2008 | 01:56 PM
ford trans tech's Avatar
ford trans tech
i recommend two
your not removing the hubs are you
Old May 15, 2008 | 07:18 PM
mejonz's Avatar
mejonz
yes I have to remove the hubs . the hubs and the drums are one assy pressed together with the wheel studs you just can't pull the wheels and drums so its a major job to do the rear brakes
plc7 Thats the first place I went they said to check with the manufacture different manufactures want different amounts of additive you'd think they would be all the same for the same axle
didn't know they made gear oil with additive already in it
thanks
Old May 15, 2008 | 11:17 PM
ford trans tech
you will have to pack the bearings with light wheel bearing grease , and after a few miles the lube will have to be topped up
Old May 16, 2008 | 09:52 AM
mejonz's Avatar
mejonz
sorry it take so long for me to reply I work at night and sleep all day I do have light grease for the bearings which I'm going to replace also since I'm going to be in there anyway hopefully won't have to do this job for awhile.
