Y-Block Rocker Ratio Question
Old Aug 14, 2002 | 01:36 PM
EZmoney's Avatar
EZmoney
Post Y-Block Rocker Ratio Question
I had an old y-blocker tell me that using the 1:54 ratio rockers on the intakes, and the 1:48's on the exhaust is the way to go. Anyone have thoughts?
1955 f100 w/ 292
Old Aug 14, 2002 | 04:55 PM
canzus's Avatar
canzus
I'd go with the 1.54's on both,
but thats just me...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old Aug 14, 2002 | 05:00 PM
pcmenten's Avatar
pcmenten
Well, that may be a way to get the intake to exhaust flow into the 80% range (where the exhaust flows 80% of the cfm that the intake flows at a particular valve lift.) This assumes a stock cam. But then the stock cams varied, too.
The intake valves on my (1956 292) engine are 1.78" and the exhaust are 1.51". I can see how a fella would want to bias the rocker arm ratio in favor of the intake.
Old Aug 16, 2002 | 01:35 PM
rogerf100's Avatar
rogerf100
Old Sep 4, 2002 | 11:56 PM
truks's Avatar
truks
Gene/ Y blocker
Find rockers with ECG on them..and use them !! They are the "performance" rockers.. They are around.. I have a lot of them..
Old Jul 23, 2003 | 04:21 PM
freezeplug's Avatar
freezeplug
do you have to use the shorter push rods with the 1.54 rockers, or are they compatible with the longer ones too?
freezeplug
Old Jul 24, 2003 | 08:28 AM
charliemccraney's Avatar
charliemccraney
EZmoney,
Are you going for performance or streetability? The 1.43 rockers on the exhaust will decrease duration and lift on the exhaust valves and more than likely cause less flow. The decrease in lift and duration may help with low end torque but hurt top end performance. I would use the same ratio rockers on the intake and exhaust. If you were running some form of forced induction, nitrous, turbo, or supercharger, using different ratio rockers would be valid. But in this case of forced induction you would want the higher ratio rockers on the exhaust valves to help the spent gases get out of the cylinder. The valves would behave more like a dual pattern cam.
Freezeplug,
The pushrod question is interesting. I use the 1.54 rockers on my engine and I purchased new pushrods for it. I just barely have enough thread on the screws to get the rockers adjusted. Just barely. So I would think that the longer ones would be best. I didn't measure mine before I installed them. That probably would have been a good idea. But as long as it works with no problems I am happy.
Kyle Wood
Nov 4, 2016 02:15 PM
NavyMIDN08
Feb 7, 2007 03:08 PM
GLASSPACK
Mar 13, 2005 10:40 PM
76 F150 Ranger XLT
Aug 24, 2004 04:04 PM
towin toys
Apr 19, 2002 01:37 AM
