302 woes
Old May 14, 2008 | 10:13 PM
MEracing45's Avatar
MEracing45
302 woes
am about to install an older 302 (77 heads and 80 block i believe) and i found one lifter that the retainer had popped out of found all the pieces but was wondering if i can put it back together or will a lifter from my 89 302 be the same and put that one in?
Old May 15, 2008 | 08:51 AM
Conanski's Avatar
Conanski
I gather this is a "budget" job. In general flat tappet lifters and the cam become a matched pair once they are broken in and you cannot replace them without applying assembly lube and going through the breakin again. Well you can do it, but it's very likely the replacement lifter will produce excessive wear on the cam lobe and it'll be junk in a short period of time. I'd suggest you use the original lifter, even if you have to use some internal parts from another to make it complete.
Old May 15, 2008 | 06:50 PM
MEracing45's Avatar
MEracing45
thanks
so i have all the parts of the old one just try and put it back together?
Old May 15, 2008 | 06:51 PM
MEracing45's Avatar
MEracing45
this is just to get the truck running and in the meantime i am rebuilding the fi
19704X4F250
16
Jan 1, 2013 09:15 PM
Huntersbo
Sep 24, 2005 07:28 PM
svt_god
Jan 28, 2004 08:45 AM
brix47
Jan 26, 2004 01:42 PM
airharley
Apr 22, 2002 05:18 AM
