problems...
Old May 14, 2008 | 08:19 PM
ford&farmin's Avatar
ford&farmin
problems...
Hey guys, sorry to bother but I have a few problems and maybe they are very simple but being as though i've got the overdrive automatic 1994 is my locking TC vacuum or electronically operated? Also my cruise was working great a couple days ago and I used it the next day and it doesn't work at all now, any ideas or suggestions as to what might be wrong or what I should look for or test, the buttons in the steering wheel test good, also the light on the overdrive/drive button on the shift select hasn't worked in years, would it be a good idea to replace it cause doesn't it blink if theres a fault in the system? thanks-hopefully im not forgetting anything
Old May 14, 2008 | 09:49 PM
KJLYPW's Avatar
KJLYPW
All electronic, get a 95 and earlier Ford code reader at Walmart, or your favorite auto parts store, about 30 bucks, all instructions included to read an trouble shoot where to start looking for problems without spending a lot of money swapping out good parts. Does you speedometer and tach work flawlessly, the need to as the transmission control uses these signals to control shifts. also, speed sensors required for the crusie control.
Search crusie control, someone posted all the diagnostic procedures some time ago.
Old May 14, 2008 | 10:22 PM
ford&farmin
Thanks for the advice, I didn't know you could get code readers that cheap, this gives some good starting points
Old May 15, 2008 | 01:59 PM
ford trans tech's Avatar
ford trans tech
since the o/d light doesnt work it usually means the wires in the shifter have broken where they flex at the shifter itself , you have to replace the shift lever to correct this
