e4od no go
Old May 14, 2008 | 08:19 PM
l'il ol diesel's Avatar
l'il ol diesel
Question e4od no go
while driving I-95 the e4od stopped working. no noise, shudders or leaks The fluid level and condition are ok. There is no response in any gear or at any rpm. the truck is a 91 f-350 4x4 7.3 idi. The tranny was rebuilt just before I bought it 30000 miles ago. Anyone have any ideas ?????
Old May 14, 2008 | 08:25 PM
JOHN CHAPPELL's Avatar
JOHN CHAPPELL
check the transfer case my 88 did something simular
Old May 14, 2008 | 08:49 PM
l'il ol diesel
thanks, I will check that tomorrow. what was the problem with your transfer case???
Old May 14, 2008 | 09:11 PM
JOHN CHAPPELL
the oil pump seazed up and took the cincro cluster out so it stayed between gears no four wheel drive no two wheel drive
Old May 14, 2008 | 10:51 PM
ford trans tech's Avatar
ford trans tech
most likely the overdrive planetary drive hub has split and the input shaft is spinning in it
Old May 14, 2008 | 11:05 PM
George D.'s Avatar
George D.
Make sure you're transfer case didn't jump out of gear. Also to eliminate the posibility of something broken in the Tcase dput it in drive and have some one watch to see if the driveshaft between the trans and the Tcase spins.
Ford trans tech is probly righ unfortunately.
Old May 15, 2008 | 12:13 AM
David85's Avatar
David85
Also possible the splined stripped out. Maybe even the TC failed, but that usually happens on acceleration.
Old May 15, 2008 | 12:18 AM
crazymike's Avatar
crazymike
ah the e40d... i cant think of anyhting good to say about it.....right now anyways
Old May 15, 2008 | 05:26 AM
PLC7.3's Avatar
PLC7.3
Check all electrical connectors......... have you done a filter and fluid change lately.
Old May 15, 2008 | 09:12 AM
starmilt's Avatar
starmilt
If it is the trans case when you put it in drive you wont be able to go back to park it will make a grinding noise no drive shaft between them to look at.
Old May 15, 2008 | 11:23 AM
David85's Avatar
David85
Complete electrical failure will not cause a no drive condition in the E4OD. with no 12v power, you will still have reverse with the selector in "R", second gear with the selector in "2" or "1", and 4th with the selector in "(OD)".
Old May 15, 2008 | 04:27 PM
l'il ol diesel
Thanks guys. I disconnected the rear driveshaft from the diff. , placed it in 4wd and the front shaft spun with the rear shaft so I believe the transfer is ok.
Old May 15, 2008 | 05:40 PM
l'il ol diesel
The tranny is puming some fluid. Does anyone know the pressures the
E4od puts out in the different gears???
Old May 15, 2008 | 06:45 PM
luthrobediesel's Avatar
luthrobediesel
id say take off the pan and see if there are any parts laying in it
Old May 15, 2008 | 07:18 PM
archangel's Avatar
archangel
NO, NO, NO!
There may or may not be trash in the pan, and that is a poor indicator of the issue as I have pulled some full of crap and they still ran, and some clean as a whistle and they would not move!
There are three (most common) places where the E4OD can fail without burning the fluid
There is the forward clutch teeth wearing out and failing causing no forward movement.
If the clutch surfaces looked good they might not have changed them missing the worn teeth.
Then there are the other two that will any kill movement in forward and reverse.
The input shaft to the OD planetary, and the output to it's planetary.
And hard shifting from a bad FIPL can cause any of the three to happen.
If the fluid is not burnt, my money is on one of those three.
