e4od no go
Old May 14, 2008 | 02:24 PM
l'il ol diesel's Avatar
l'il ol diesel
e4od no go
while driving I-95 at 65 mph the e4od in my 91 f350 diesel stopped working without any warning. No noise , vibration or anything. there is no response in any gear. I have had no previous problems with it. The tranny was rebuilt about 20,000 miles ago. Any ideas?????Fluid level and condition seem finr.
Old May 14, 2008 | 06:54 PM
sclariat's Avatar
sclariat
2wd or 4x4?
Old May 14, 2008 | 07:59 PM
l'il ol diesel
4x4 f350 7.3 idi 192000 miles runs like a dream
Old May 14, 2008 | 08:57 PM
projectSHO89's Avatar
projectSHO89
Probably sheared the pump shaft.
Quick check: Disconnect one of the cooler lines and start the engine. If there's little to no flow, the pump ain't working anymore.
Steve
Old May 14, 2008 | 09:29 PM
sclariat's Avatar
sclariat
Yes the pump shaft is the most likely. The reason I asked 2wd or 4x4 is that another possibility is the transfer case is neutralizing.
Old May 15, 2008 | 04:22 PM
l'il ol diesel
I disconnected the rear driveshaft, put in 4wheel and turned the rear shaft. the front shaft turned with it so the transfer case is ok I believe. thanks for the info!!!
Old May 15, 2008 | 05:44 PM
l'il ol diesel
The tranny is pumping some fluid. Does anyone know the pressures this tranny develops??????????
Old May 15, 2008 | 06:44 PM
projectSHO89
The pump should be able to shoot the fluid several feet from the cooler line.
Internally, line pressure should be around 55-65 psi at the LINE tap. You'll need the appropriate gauge and to attach it at the correct port.
At the cooler return line, you should get about 1 quart of fluid flow per minute. If you're getting that, the pump is at least working some although it may not be able to develop (or maintain) adequate line pressure to operate the hydraulics.
We'll assume you've verified the fluid level.
Steve
Old May 15, 2008 | 08:51 PM
sclariat's Avatar
sclariat
That doesn't mean anything. The 4wd engagement has nothing to do with the input/planetary. maybe try 4x4 low. And check the oil.
Old May 16, 2008 | 02:06 PM
l'il ol diesel
Oil level and condition is good. pumps a quart in 30 to 45 seconds but doesnt seem to have much pressure. Got aprice from a reputable shop of $1800.00 to remove upgrade and reinstall and will have it done two days after it is delivered. I guess I will go with that. Thanks again for your advice.
