backup sensor and light problems
Old May 14, 2008 | 09:28 AM
catman700's Avatar
catman700
2004 F-150 Lariat - my backup sensors (factory) quit working (says off on the dash whenever truck is in reverse) and shortly after they quit my backup lights quit working. I tried changing the switch on the transmission and that did not change anything. All the fuses are good. Bulbs are good. Been reading and the most likely cause for the sensors is a faulty sensor. Does anyone know if I can test them myself with an ohm meter or do I have to get this done at the Ford dealership? Any help with the backup light or anymore suggestions on the sensors would be greatly appreciated as I am at a loss right now.
Old May 14, 2008 | 12:11 PM
Twinsdad98's Avatar
Twinsdad98
I would think you could test them with an ohm meter and do the diagnostics yourself. I will look at my manual when I get home and see if there is a procedure to trouble shooting this. Not sure why the backup lights would go out at well. I would have thought Ford would have made them independent for safety reasons...
Old May 14, 2008 | 05:03 PM
catman700's Avatar
catman700
Thanks let me know what you find out
Old May 14, 2008 | 06:19 PM
FatalErrorz's Avatar
FatalErrorz
Isn't there a switch on the shifter column also? For the console mounted ones?
Old May 15, 2008 | 08:05 AM
Twinsdad98's Avatar
Twinsdad98
I looked at my manual. I could try to scan them in and post them or email them to you. However, there should be codes stored in memory for the Reverse sensors. Do you have a way of pulling the codes? That would definitely help your trouble shooting.
Old May 15, 2008 | 11:15 AM
catman700's Avatar
catman700
Thumbs up
If you could e-mail them to me that would be great. If you want you can send them through the forum here or just e-mail me throught the forum and I'll e-mail you my address. Thanks for your help.
Old May 15, 2008 | 02:07 PM
Twinsdad98's Avatar
Twinsdad98
WIll do, I'll scan the pages in when I get home and try to get it to you tonight after my son's soccer practice.
Old May 15, 2008 | 02:19 PM
catman700's Avatar
catman700
No hurry I'm leaving town this evening and won't be home again till Wednesday next week.
Old May 19, 2008 | 09:58 PM
catman700's Avatar
catman700
Have you got a chance to scan those plans yet?
black & blue 78/9
Apr 7, 2016 06:35 PM
ianobetz
Feb 27, 2016 03:37 PM
HAMMERDOWN103
Mar 27, 2014 02:16 PM
Vaokie1
36
Jan 31, 2014 03:29 AM
lightninquick
Dec 9, 2011 09:35 PM
