Offroad & 4x4
D44HD Vs. D60
Old May 14, 2008 | 01:48 PM
ford_4.0's Avatar
ford_4.0
An hd44 is just bigger brakes right? Nothing really special or exciting about them.
Old May 14, 2008 | 01:55 PM
littleme13's Avatar
littleme13
yes they have a 8 lug outer knuckle with bigger breaks. its basically to match the 8 lug bolt pattern to use on the 250s with the 8 lug 60 rears.
Old May 14, 2008 | 02:28 PM
Thomasm67's Avatar
Thomasm67
From what i understand a D44HD is just a d44 with D60 outers for the 8 lug rims and bigger brakes.
Old May 14, 2008 | 02:33 PM
ford_4.0's Avatar
ford_4.0
How would a D44 do with a stock 4L ranger? I think I saw someone else with a 44 and an 8.8, but he had a built motor.
just a thought.
Old May 14, 2008 | 02:46 PM
captain p4's Avatar
captain p4
Could probably run a 37/38 pretty reliably with as light as the rangers are. I know a lot of jeep guys swap in the explorer 8.8 because its strong enough for them and has disc brakes.
But if I were going through all the trouble to SAS a ranger I'd probably just go right for the one ton stuff and never worry about it again.
Old May 14, 2008 | 03:39 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Nope...
just the brakes. D44HDs only share rotors and calipers with D60s. Nothing else is the same.
Like I said...there is nothing HD about a D44HD.
For a trail truck on 38-40s with a 460 you'd be an idiot to SAS a D44. 60 rears arent the best either for that combination. Id go with a 60F with a 70 or Sterling rear.
Old May 14, 2008 | 08:28 PM
kjett's Avatar
kjett
Yep!!! x2!
Old May 14, 2008 | 11:01 PM
teds74ford's Avatar
teds74ford
To add to the D44 info: they use the same stub shafts and lockouts as the half ton stuff.
As previously stated: the ONLY advantage to a D44HD is better braking.
Old May 15, 2008 | 08:45 AM
fishmanndotcom's Avatar
fishmanndotcom
anything closed knuckle sucks! just keep shopping!
is the pinion high or low?
i bet ya someone swapped in a closed knuckle D60 thinking it would be stronger than a 44 but he was dead wrong!
-cutts-
Old May 15, 2008 | 06:40 PM
dave75's Avatar
dave75
A HD dana 44 hub is way bigger then a regular 44 hub that you might find in a F150. Believe me, I have one in my 75 ford. Axle shafts are the same diameter but the u joint is a litter bigger. 5-86x
Dana 44 Solid Front Axle: Reverse Spiral and Standard Housing info..
Check out the hubs
Old May 15, 2008 | 06:53 PM
STGFordCrazy04
nope.
My warn hubs in my 79 F150 were the exact same part number for the D44HD in my 79 F250. 5-860X is a D60 U joint.
Im not trying to be cocky with you bud but you cant beat me on most Dana knowledge. Lets just say Ive done my fair share of reading/watching/learning/building/breaking/fixing
Old May 15, 2008 | 06:55 PM
STGFordCrazy04
Direct quote from littlekeylimes site
Top shaft is a 5-86x u-joint style axle shaft, bottom is a 5-297x style shaft.
If only this heavy duty 5-86x u-joint axle shaft would fit in a Ball Joint Dana 44.
Old May 15, 2008 | 07:17 PM
  #28
captain p4's Avatar
captain p4
Well good news for dave75 then, if he has a 5-86x u-joint and bigger hubs on his "D44" its probably a d60, hmm?
Old May 15, 2008 | 07:21 PM
  #29
dave75's Avatar
dave75
5-86x was used in closed knuckle hd dana 44 and the same joint was used in closed knuckle 60
Old May 15, 2008 | 07:24 PM
  #30
STGFordCrazy04
got any pics?
