i have a 94 f150 4x4 and i need to change the front rotors. i know they need to be pressed and trying to find out info on what i need to do. do i just have to press the lug studs or does the hub need to be pressed in? thank you for any info
the rotors and the hubs are just held to gether with the lugs. I've done it once on a half ton 4wd and once on a 3/4 ton 4wd. You will need to take off the locker, and all that. then tap the lugs out. replace the rotor, tap the lugs back in and tighten the lugs with a lug nut put on BACKWARDS. this should get you there.
the rotors and the hubs are just held to gether with the lugs. ... the lugs back in .....the lugs with a lug nut put on BACKWARDS. this should get you there.
