Stock Height
Old May 13, 2008 | 06:06 PM
TxSprDty's Avatar
TxSprDty
Stock Height
Guys,
What is the stock height in the back for an 06 F-250 FX4. I bought my truck used a year ago and i have noticed it sits pretty level in the back, is this normal or maybe it's just me. Does anyone know the size of the blocks in the rear so that i can measure and compare. I'd much rather it sit up a little than be level.
Old May 13, 2008 | 06:15 PM
GregsSD's Avatar
GregsSD
The F-250 4x4's use a 2" block (acually just under 2")
You can switch to the F-350 blocks (F-350's use a 4" block) and some F-350 u-bolts which will give you 2" of lift.
Old May 13, 2008 | 07:28 PM
TxSprDty's Avatar
TxSprDty
It would give me 2" of lift, huh? That's great. Where can you get F-350 blocks?
Old May 13, 2008 | 07:31 PM
TxSprDty's Avatar
TxSprDty
I've just noticed several F-250 that do not have any kind of lift that i can tell but look noticeably taller than my truck. What else is there that could give them this look other than larger wheels and tires?
Old May 13, 2008 | 08:04 PM
UGA33's Avatar
UGA33
you can get them at the dealer or the FTE parts guy. His advertisement is always on the main page. You can also check the FTE classifieds. I did the 350 blocks on my 250 and it was really easy to swap. I was able to get a hold of the hardware for free, so i basically just paid $290 for a 2.5" lift.
Old May 14, 2008 | 07:05 AM
saftman's Avatar
saftman
Mine used to sit a little higher in the back until I started pulling a fifth wheel camper. Now it is just about level. Your truck probably was hauling something by the previous owner.
Old May 14, 2008 | 12:53 PM
TxSprDty's Avatar
TxSprDty
Quote: "Mine used to sit a little higher in the back until I started pulling a fifth wheel camper. Now it is just about level. Your truck probably was hauling something by the previous owner"
Is this correctible or not? I bought it with 16,000 miles on it so i wouldn't think that would be enough time to cause it to sag.
Old May 14, 2008 | 01:23 PM
saftman's Avatar
saftman
Probably not without changing the springs. These springs are a little"mushy" and tend not to return to their original height after being loaded several times (at least that is my experience). I personally wouldn't put the blocks from a F350 because i use my truck for work, towing, riding customers in, etc. It is tall enough for me allready.
Old May 14, 2008 | 03:07 PM
UGA33's Avatar
UGA33
the 05-07 250's sit pretty close to level compared to the 99-04 250's. Mine sat pretty close to level when i drove it off the lot.
Old May 19, 2008 | 11:12 AM
karynzoo's Avatar
karynzoo
mine sits level, bought it at 14miles and it hadn't pulled anything that I'm aware of just an occasional day driver. Now I get alot of bouncing in the truck when I pull my GN. SOme of the suggestions I've gotten is that the shocks are shot or the springs are not doing their job. I'm not a teckie so going to have my trailer guy check it out. I figure if it is bouncing the heck out of me my horse isn't very happy either in the trailer.
