Alignment issues.....
Old May 13, 2008 | 01:23 PM
Joe_T's Avatar
Joe_T
Question Alignment issues.....
Hi, everyone.
I have a puzzling dilemma with my 2000 Ranger 4x4.The truck developed a pretty good pull to the right.It may have been there when I bought it,but seemed to get worse.
I have had the alignment done 3 times.I've had the tires switched side to side,and rotated front to rear.The steering wheel is straight and all the alignment specs are in range.There is no brake drag or hubs stuck or any of that.But yet the pull persists. It's not severe, but enough to have to hold the wheel straight, and its aggravating.
Any ideas out there??????
Any suggestions greatly appreciated!!!!
Joe
Old May 13, 2008 | 02:59 PM
Pablo-UA's Avatar
Pablo-UA
Ouh... are you sure camber and caster and KPI are symmetricaly aligment. I need figurs to see what is wrong. What tools did you use to align? What instruments?
Old May 13, 2008 | 03:04 PM
Joe_T's Avatar
Joe_T
We have a brand-new Hunter alignment machine in the shop where I work.I'll have to find the print-out with the specs.
Or I'll ask my guys if they can bring them back up and print them out.
Old May 13, 2008 | 03:07 PM
Pablo-UA's Avatar
Pablo-UA
I use Josam Truck Aligner-II. Good mashine too.
Did you pass all tests to measure camber, caster, KPI, toe-in? have you all wheel bearings good?
Old May 13, 2008 | 03:21 PM
Pablo-UA's Avatar
Pablo-UA
Ok. I'll be back tommorow. Wait for figures...
Old May 13, 2008 | 03:31 PM
Dan Robertson's Avatar
Dan Robertson
Are you sure that it is not a brake caliper sticking?
Old May 13, 2008 | 04:13 PM
Joe_T's Avatar
Joe_T
Yes,I'm sure Dan,the calipers were replaced a few months ago, and I did check and they are not sticking.Wheel bearings seem ok too,dont feel any drag with the wheels off the ground.
Yes Pablo,all with specs according to the last alignment.I'll try to find the print-out.
Old May 13, 2008 | 04:18 PM
Joe_T's Avatar
Joe_T
BTW before someone says it, the ball joints have already been replaced and are ok!!!!!!!
BlackNGoldRules
Aug 9, 2010 07:14 PM
95F150Guy
Jan 30, 2010 10:01 PM
flat4vw
Oct 14, 2004 01:56 PM
Stephen
2004 - 2008 F150
May 9, 2004 01:56 PM
mrak
Jun 4, 2003 07:37 PM
