94 clutch bleeding nightmare
94 ranger xlt,standard cab,2.3L,5spd.,125,000 miles
replaced clutch,pressure plate,slave&throw out
everything went well..out and back in in 1 day.
been bleeding the line ever since..
roomy let it run dry trying to bleed it by himself..
i ran it dry a few times before i replaced the clutch (slave leaking)
and just put fluid in and bled it real quick..and was good..
i have been bleeding this clutch for 4 weeks..
bought a pressure bleeder from Eastwood..
nice tool..but still hasn't done the job..
already have a new master cylinder on hand..
but i really don't think there is anything wrong with the old one..
these things are a nightmare to bleed!!
any help..THX a lot!
found the article here under tech advice and bleeding slave cylinder
which actually is more about the master cylinder...but..anyways...
will try that..but go ahead and post any advice you may have...
During the re & re of the hydraulic line, you didn't have any difficulty that may have damaged the tube, right? It came off & went back on nice & easy?
You've got nothing to lose by changing the master at this point.
Good luck!
AL.
If you don't have Phoenix Injector tool, then try a reverse bleeding. hook up pressure bleeder to slave cylinder [ will require some fabrication to make it work.]
unscrew the clutch master cylinder cap, turn the pressure bleeder on and watch the fluid level rises inside the clutch master cylinder.
The reason for that is the clutch master cylinder does not have piston return spring inside and the pressure bleeder will force the piston toward to clutch pedal pushrod.
Good Luck
inside the cab, pull the starter interlock from the clutch rod, disconnect the rod from the pedal arm. You will see a circlip in the master over the piston. Pull the circlip, pull the piston till just the air and a little fluid escapes, pump the master a couple of strokes repeat the above, reasemble than bleed per the manual, open the bleeder and let gravity bleed. Might have to bleed the bleeder a couple of times, biggest thing is the air in the master.
Hank
i think the tube is fine...but:
i went ahead and bought a new one anyway ($83.00)
think i will just bench bleed the new master cyl.
per: hank's instructions..
and put the new master and new master to slave line..
i already bought 'em what the hey...
then i will know ALL is brand new..
and should be good for many miles..
thx for all the help...
will let you all know how it goes...digging in this afternoon.
i have replaced everything brand new..
and bled and bled...i know it's bled..
put on new slave cylinder from factory..
3/16" difference in height from factory to autozones replacement..
pulled out autozones new replacement slave..
and could push it down easily..
had bench bled new factory slave..and could not push it down by hand..
thought i had the problem fixed..(bad slave from autozone)
beld it again,looked good..WILL not go into gear!
if i put it in gear..then start it..it will drive..just can't change gears
clutch seems to work,engages normally if i put it in gear first..1st & reverse anyway
can drive it in & out of garage..just can't change gears
confused,lost and puzzled.
i have been working on this for 8 weeks..
out of ideas..have pulled the tranny 2x...
guess it's gotta go to a shop...
i am exhausted from this...
I agree that bleeding these clutches is a pain. When I finally got all good parts in it, I had air in the master, and did a procedure very much like the one that was listed above. Even then I had to bleed it again about a month later to get the rest of the air out.
Just as a note: the new slave shouldn't be all that hard to push in, the only thing you are pressing against, if you have the bleeder open or haven't filled it with fluid yet, is the spring it's self.
--Toxic
Fill up the resivoir..
crack the bleeder nut open..let the fluid come out on it's own..you'll see the fluid level in the resivoir begin to drop..tighten the bleeder nut back up..top of fluid in the resivoir and you're done. basically you're gravity bleeding it.
out of ideas..
Hopefully, you won't spend 8 more weeks on it !
I have now solved the problem and it wasn't bleeding after all.
First, Ford garages do not mill flywheels to cleanup the surface. They simply replace them. They told me to do the same, but a mechanic friend advised me to simply shim the flywheel (between the flywheel and crank flange) the same amount that was removed from the surface. It worked. I simply used shim stock and gently hammered out the circle/bolt patterns as you would a gasket.
Then I replaced the aftermarket pressure plate, clutch and slave (from AutoZone) with genuine Ford parts. The slave alone was 1/8" longer. When I reassembled the unit, the clutch worked better than ever before. The key, it turns out, is the critical dimensions (since the throwout setup is not adjustable). All parts are not created equal, I found.
Hope this helps someone else.
John McDonald
Murray, Kentucky
In my situation, I too had the flywheel shaved/milled/resurfaced. No idea how much they took off though... ??
The thing that worked out for me was to "Bench Bleed" my clutch hydraulic system and then install it.
Has anyone come up with a full proof SOP for bleeding the clutches from bench bleeding to bleeding it on a hill?
Thanks
The method that I think works the BEST is to Bench Bleed the system and "then" install it.
Believe you me! I've tried ALL the methods lately and Bench Bleeding definately is the EASIEST and MOST effective methos to do!
