351 starter probs
Old Jul 24, 1999 | 08:40 AM
kaos_agent1's Avatar
kaos_agent1
351 starter probs
<center><font size="1" color="#ff0000">LAST EDITED ON Jul-24-99 AT 10:10&nbsp;AM (EST)</font></center>
Last year I purchased an 85 f-150 4WD with a rebuilt engine 351, w or c. I don't believe it is the original motor. The former owner knew even less about it than I do. The new starter I bought for the truck was slightly smaller in diameter than the old one and I need to know how to find out what motor I have so I can start solving my mechanical problems. The truck starts fine when cold, but won't turn over when hot. I have replaced starter, solonoid, alternator, battery, new cables, set timing. Still same prob.
Old Jul 24, 1999 | 09:09 AM
deleontow's Avatar
deleontow
351 starter probs
You probaly have a 302 or 351W as the 351 C has not been made since 1974. Type me back with your vin and I will tell you what you have
deleontow(No Email Addresses In Posts!)
Dave
Old Jul 24, 1999 | 03:27 PM
deleontow's Avatar
deleontow
351 starter probs
You typed me back with a vin
FTEX14H0FKB37069
1 = US BUILT
F = FORD MOTOR COMPANY
T = TRUCK
E = 6,000 - 7.000 GVW
X14 = FORD PICKUP F150 4 X 4 SUPER CAB
H = 351W MOTOR 5.8 L 4BC
0 = CHECK DIGIT
F = 1985
K = KANSAS CITY *** PLANT
B37069 SEQUENTAIL SERIAL NUMBER
DAVE
Old Jul 24, 1999 | 10:06 PM
slik's Avatar
slik
351 starter probs
I just put a new 351W in my F150. Had the same problem and couldn't find it. I replaced everything just like you did and still had the same problem. Hauled it in to my mechanic, and he found my new battery had a dead cell; new battery, problem solved. A friend of mine just put a 302 in his truck; same thing with starter problems; had to replace with at least 3 starters before he got a good one. Check to see what your starter is pulling when it cranks; pull the lids off the battery and put a load on the battery and see if one cell boils (if it does, it's toast). Then check your amps, section by section from the battery to solenoid, across solenoid; from solenoid to starter. Also check for a good ground to the block off your battery.
LOL,
Slik
Old Jul 25, 1999 | 10:04 AM
J. D.
Guest
Posts: n/a
351 starter probs
fixed the problem. I moved the negative ground from the frame to the bolt where starter bolts to the bell housing.
Old Jul 26, 1999 | 12:11 PM
slik's Avatar
slik
351 starter probs
rkik
31
Sep 3, 2017 10:11 PM
StangStang
Aug 23, 2016 10:15 AM
GaryKip
16
Mar 8, 2016 01:12 AM
justenuf2b
48
Dec 5, 2013 10:45 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
