Squeak i reverse only
Old May 13, 2008 | 07:00 AM
dan01247's Avatar
dan01247
Hi all,
1988 F-150 4x4. Auto, 4.9l. Manual hubs
Last week I noticed a very pronounced "squeak" when I back up. It is a high-low repeating noise, and it is only when the truck is moving. It increases speed as the truck increases speed, and stops when the truck stops.
I put the rear end on the floor jack and put the truck in reverse, and I didn't hear it. I put the front end on jack stands and tried it again. No noise. But when the truck is on the road and I back up, the noise is there... Apparently, it is only when there is a load on it.
Before I go and reinvent (or tear apart) all the wheels, does anyone have any thoughts as to what I should be looking for? It sounds like it's coming out of the back....
Thanks!
Old May 13, 2008 | 07:34 AM
Conanski's Avatar
Conanski
I'd suspect a driveshaft U-joint.
Old May 13, 2008 | 02:04 PM
dan01247's Avatar
dan01247
Thanks for the thought - since U-joints are pretty cheap, I put two new ones in today. Still have the noise, though...
Any other thoughts? I'm pretty sure that it's coming from the rear.... A friend of mine listened to it when I was backing up today (with the new universals), and mentioned that it sounded like a bearing in the rear-right. I've not heard a bearing squeak, or only in reverse....
I'm stumped...
15
Jan 25, 2017 03:41 PM
possom813
Sep 8, 2016 11:10 AM
Thunderknight
Escape & Escape Hybrid
Jul 31, 2015 10:25 PM
fordboy67
Aug 6, 2008 01:56 PM
Ranger Steve
1983 - 2012 Ranger & B-Series
Sep 6, 2006 06:53 PM
