help stop the leak
Old May 13, 2008 | 02:35 AM
superman724's Avatar
superman724
help stop the leak
My used 2002 x diesel 4x4 is leaking anti freeze thought it was the water pump so i changed it still leaking. Then I added the stop a leak into the radiator stopped for a few days just started doing it again, any ideas what it can be . Please HELP
Old May 13, 2008 | 03:07 AM
Monsta's Avatar
Monsta
Sit. Stay.
Where it is leaking from??
Old May 13, 2008 | 03:28 AM
superman724
no idea i will check again tomorrow in the daylight and post a pic am also gonna add a dye to see if it shows where its leaking from. Hoping someone had an idea. Btw whats mpg on one of these beast, it has about an 8inch lift with 37 inch tires and the computer says 10.7 whether on the street or on the freeway and if im towing or not it never changes
Old May 13, 2008 | 04:56 AM
Stewart_H's Avatar
Stewart_H
I hate that stop leak stuff. Just the thought of that crap flowing in my coolant gives me the heebies.
Like Ken posted, you need to follow the path of the coolant to determine where you're leaking from.
I assume you're finding a puddle under the truck? Is it just wetting the pavement, or is it actually puddling?
Stewart
Old May 13, 2008 | 09:53 AM
superman724
no it only does it occasionally and its only a few drops at a time i filled it with water on Friday drove it to Bakersfield on Saturday and it was fine yesterday I noticed it started leaking again. But I cant tell where its coming from, could it be one of the hoses, anybody else have this problem. Thanks guys
Old May 13, 2008 | 09:56 AM
aklim's Avatar
aklim
Can you wash the truck engine off and dump dye in the coolant and probe around with a black light?
Old May 13, 2008 | 09:59 AM
superman724
planning on doing that today or tomorrow on my day off hopefully that can show me where the problem is
Old May 13, 2008 | 06:13 PM
superman724
I think i found the problem it looks like one of the hoses is leaking will keep you posted
Old May 13, 2008 | 07:57 PM
JT!'s Avatar
JT!
Egr Cooler hose most likely
Here is a post to look at https://www.ford-trucks.com/forums/6...oler-hose.html
