Sponsored by: Real Truck
05-08 v10 headers?
Old May 12, 2008 | 10:54 PM
jayjma20's Avatar
jayjma20
05-08 v10 headers?
does anybody make them or do the 2v headers work?
Old May 14, 2008 | 04:39 AM
npccpartsman's Avatar
npccpartsman
If you'll do some research you'll find out that headers on a V-10 actually cost you HP. I know it seems contradictory, but it has something to do with the design of the motor.
Old May 14, 2008 | 05:51 AM
Furian's Avatar
Furian
You Keep What You Kill
I've been searching for headers for my recently purchased 2005 F350 4x4 with the 5.4L engine. Ford used a 2" collector on the 5.4L exhaust manifold so any header designed to fit the stock y-pipe will also have a 2" collector. I don't see the point of replacing the stock exhaust manifold at a cost of around $600 to continue to be limited by a 2" collector.
I don't know what size collector is used on the V10 engine. Banks offers a kit that includes headers for your truck (see link below). You can call them at 800-601-8072 for more details.
Bankspower - 6.8L V-10, '99-06
JBA offers a shorty header as well. Summit sells them at the following link:
Headers - summitracing.com
I think that the aftermarhet is still playing catch-up with the new 3V engines.
Best success!
Andrew
Old May 14, 2008 | 01:06 PM
Monsta's Avatar
Monsta
Sit. Stay.
Ford Racing has a set for the V10.
Search in the V10 forum. Captchas put a set on his but took them off, if I recall correctly (IIRC) due to lack of performance increase.
Old May 15, 2008 | 10:08 PM
V10man's Avatar
V10man
If you look at the stock manifold, it is "header like" already. With the dual cats, and no way really to use long tube headers like on the 99-04 there really is no gains to be had with the shortys.
Old May 16, 2008 | 08:38 AM
dkf's Avatar
dkf
JBA makes a set for the 6.8l 3V V10. I personally don't buy the thinking that headers on the 3V V10 won't make more power, but they make not make much more than stock. The 5.4l 3V responds very well to headers such as the JBAs, I've seen dyno #'s to prove it. Granted the 3V V10 doesn't have VVT or as much compression as the 5.4l 3V, but its hard for me to believe there are no gains even if a small amount to be had even with shorties on the V10. I've never seen dyno info on 3V V10 headers but they do the job on the 5.4l quite well. Maybe some custom tuning needs to be done in conjunction with the headers. Notice though Banks does not make headers for the 3V V10, power gains must be minimal if Banks doesn't offer headers for the 3V V10. All they offer is a cat-back for the 3V V10.
JBA Performance Exhaust Part #:1670SJT Cat4ward® Shorty
The 2V V10 no doubt responds better to headers than the 3V due to the 2V having crappy manifolds and a horrid y-pipe from the factory. The 05' manifolds and exhaust are much better.
Old May 16, 2008 | 10:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I completely disagree.
On the 2-valve, my headers obviously make much more high-end power, and did not hurt the low-end torque whatsoever. And those are cheapo eBay shorties.
On the 3-valve, gains wouldn't be as noticable, because as was already mentioned, the 3-valve has exhaust manifolds that aren't so "log-style" as the 2-valver's. But with the right headers, there has to be some more power there.
Old May 16, 2008 | 12:25 PM
dkf's Avatar
dkf
Well said. The Thorley headers on my 2V really perked it up, especially down low where you need it most.
To answer the OP question. No, 2V V10 headers will not work on the 3V V10 and vise versa. I've heard the 3V manifolds won't fit on the 2V but I don't know for certain.
Mud-and-Guts
Modular V10 (6.8l)
25
Feb 19, 2011 11:26 PM
koda55
Modular V10 (6.8l)
Sep 29, 2010 08:27 AM
mooncricket
Jun 23, 2007 01:52 AM
ranger pat
Sep 12, 2001 10:25 PM
pwall
Bronco II
Jul 15, 2000 10:53 PM
