Air Suspension
Old May 12, 2008 | 09:17 PM
Billholthues's Avatar
Billholthues
Air Suspension
Hello All!
I have an 03 Navigator. Over the past few days the check suspension warning has come on. Sometimes it will go away if you shut the car off, other times if you turn the suspension off it will then check out ok on the system check. Any help would be appreciated
Thanks
Bill
Old May 12, 2008 | 09:49 PM
sbclemens's Avatar
sbclemens
Search this site for "air suspension". This is a common issue that has been addressed in numerous threads.
Old May 12, 2008 | 09:52 PM
Billholthues
Thank you!
Old May 12, 2008 | 09:59 PM
Billholthues
I tried to put "air suspension" in the search, and there is some kind of error with finding results because it says that my search terms confuse the sight
Old May 12, 2008 | 10:14 PM
sbclemens's Avatar
sbclemens
I think somethings gone south with the search engine. If you type in anything in the field it gets confused. Theres a recent post that has a link to some good info on air suspensions. Try it until the search engine comes back up.
Lincoln Air Suspension Parts for 1984 - 2002 automobiles
